Also posting in here in case someone can help:
This fork of the component works for v2 devices:
Is based on both @no2chem (hass-smarthinq v2) component @ollo69 (wideq v2) library versions
HOWEVER: If you have mixed v1 and v2 devices it might break you setup. I installed this fork and tried to keep the original component but seems that there is only one wideq version possible so there are issues in one or the other.
If somebody knows how to keep both wideq versions to co-exist so we can use both components at the same time please let me know!
Boiiiiiii!!! This works, finally after months I can see my LG aircon in home assistant.
It’s still not 100% because I cant get current temp and stuff but I can adjust temp and change modes.
So now my LG HVAC on api2 is finally working, does anyone know how we might get my zone motors to open/close via the api as well? I can control which rooms are open/closed from the LG app just in the “Zone” section.
Was just planning to put sensors in certain rooms and perhaps control the flow a bit
I see many query on eic.lgthinq.com, several per minutes (every 30 seconds?), on my pihole logs. Is it normal? Can’t it be lowered to something to one ping each each 5 minutes? Or only when one of the appliance is active?
My old washer dryer finally died () which means I can now justify a smart replacement lol. Had a LG FWV685WSE washer dryer delivered, installed ollo69’s component from HACs according to instructions and everything worked first time. Thanks to everyone involved!
For installation I have choosen Option B: Manually installation (custom_component), because I couldn’t find SmartThinQ LGE Sensors in the Integration tab. After that I rebooted HA. For the configuration I want to use the Option A: Configuration using the web UI [recommended]. But again, I can not add SmartThinQ LGE Sensors as a new integration. What I am doing wrong?
Hi @samps and @wkd8176, would it be possible for you guys to add Jet Mode, Energy Control and Air Purifier to this codes of yours? I would like to volunteer if needed as Alpha tester. Thanks! More power to you guys!
I have two of the new LG thinQ Ceiling Fans, was hoping to integrate them with my Home Assistant.
i managed to install and configure https://github.com/ollo69/ha-smartthinq-sensors
It seems like there’s no support for the Fan device type. What is the best way to try and get this device type added ?
i get this message in my logs:
Logger: custom_components.smartthinq_sensors.wideq.device
Source: custom_components/smartthinq_sensors/wideq/device.py:272
Integration: SmartThinQ LGE Sensors ([documentation](https://github.com/ollo69/ha-smartthinq-sensors), [issues](https://github.com/ollo69/ha-smartthinq-sensors/issues))
First occurred: 12:20:49 PM (2 occurrences)
Last logged: 12:20:49 PM
* Device d16a0770-6d79-1583-9478-24e853162483: unknown device type with id 405
* Device 8d758d50-d36b-17b8-a5ad-24e853164537: unknown device type with id 405
Add fan should not be really complicated.
Please open an issue in integration repository as feature request add attach the fan JSON device information.
First of all install new version that I just released today, I have added device type 405 so that is not unknown any more.
After reboot open the HA logs, you should find a web link to download JSON info. You should have a couple of lines like this:
Thanks @ollo69 - i’ve upgraded the component, the error in my logs is now gone but im not seeing the anything in the logs like you describe. To confirm im looking in the right place, it’s : Configuration (side bar) → logs → load full home assistant log (button)
all i see is this:
2021-09-20 12:54:57 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration smartthinq_sensors which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
You need to check inside the log file and search for message at info level.
If your log level is set to warning you should set it to info in configuration.yaml to have required messages.
I am in the same boat. I can’t find smarthinq in HA integrations. I can’t do the component web configuration . I am lost and I don’t know what to do. If you found a solution please let me know
