In development: LG SmartThinQ component
Nope, this is an active project and has been working great with my washer/dryer for quite some time.
It mostly works, but… I can’t figure out how to get rid of these yellow/orange triangles? Even when a cycle is running and the time is displayed, it’s just displayed on top of the triangles and you can still see them behind the time. Has anyone run into this, or does anyone have any ideas how I can fix it?
EDIT: I just figured it out. You need to leave the “sensor blank” sensor in the config. The directions said to remove any sensors you don’t have (dishwasher, etc), so I had removed that as well. Oops!
I’m having the same issue as the poster above – remaining time is not displaying.
Anyone know what’s up?
I do not have an entity named “sensor.blank”, however I left the config in my dashboard:
          - type: picture-elements
            elements:
            - type: image
              entity: sensor.lg_dryer_run_state
              image: /local/lg-icons/dry.png
              state_image:
                Drying: /local/lg-icons/dry-on.png
              style:
                top: 33%
                left: 69%
                width: 20%
                image-rendering: crisp
            - type: image
              image: /local/lg-icons/cool.png
              state_image:
                Cooling: /local/lg-icons/cool-on.png
              style:
                top: 33%
                left: 87%
                width: 20%
            - type: image
              image: /local/lg-icons/wifi.png
              state_image:
                'on': /local/lg-icons/wifi-on.png
              style:
                top: 73%
                left: 32%
                width: 10%
            - type: state-label
              entity: sensor.blank
              prefix: '18:88'
              style:
                color: '#555'
                font-family: segment7
                font-size: 50px
                left: 95%
                top: 74%
                transform: 'translate(-100%,-50%)'
            - type: state-label
              entity: sensor.lg_dryer_time_display
              style:
                color: '#8df427'
                font-size: 50px
                left: 95%
                top: 74%
            image: /local/hass-dryer-card-bg.png
          - type: conditional
            conditions:
              - entity: sensor.lg_dryer_run_state
                state_not: '-'
            card:
              type: entities
              entities:
                  type: attribute
                  attribute: current_course
                  icon: 'mdi:tune-vertical-variant'
                  type: attribute
                  attribute: temp_control
                  icon: 'mdi:thermometer'
                  type: attribute
                  attribute: dry_level
                  icon: 'mdi:air-filter'
Yeah, looks like you did the same thing I did. The sensor.blank would be in your configuration.yaml where you put the sensors for the washer & dryer.
I actually just filmed a video about this the other day. Just need to do the voice-over and editing and get it up to my YouTube channel. Hopefully within the next day or two. I’ll post a link when I get it finished and published.
Sorry it took so long… Life kind of got in the way.
Here’s the video:
I had a fantastic automation working with LG Washer Dryer. It announced the end of a cycle on all my Echo devices. Now, for some reason, I get the alert tone, but there’s no TTS afterwards.
  • id: ‘1647953183092’
    alias: Washer
    description: ‘’
    • type: turned_on
      platform: device
      device_id: 1bd3a96a9422342d7194f17d23a5e287
      entity_id: binary_sensor.washer_wash_completed
      domain: binary_sensor
      condition: []
    • service: media_player.volume_set
      volume_level: 0.5
      device_id:
      • 1b6c4b692ea4c530d934705c6dd24270
      • 4afbfeaaf40482a7ac5a95197287deeb
    • delay:
      hours: 0
      minutes: 0
      seconds: 1
      milliseconds: 0
    • service: notify.alexa_media_scott_s_echo_show_8_2nd_gen
      message: The current washer cycle is complete
      type: tts
      method: all
      mode: single
Did anyone ever find a fix for this? I have the triangles… and the timers don’t work.
Yes. You have to not delete the “blank” sensor from the config. Watch my video a couple replies up for a step-by-step to set this up.
EDIT: Actually, if you don’t have the timers, either, you probably missed the ENTIRE configuration section. Either that, or you didn’t restart after adding those sensors. Regardless - I recommend you watch the video since it’s all covered in real-time. Let us know if that solves it for you.
Thanks for the reply. I deleted the cards and reinstalled them, following along with your video, but I get the same result.
The blank sensor is at the end of the configuration.
blank:
      friendly_name: "Blank Sensor"
      value_template: ""
The hard work is done; I can live with it.
I don’t believe that the issue is with the cards. If the yaml that you posted accurately reflects your config file, then the problem is most likely that the spacing is incorrect. Yaml is very sensitive to spaces.
The sensors for washer and dryer in your config file should look like this:
    washer_door_lock:
      friendly_name: "Washer Door Lock"
      value_template: "{{ state_attr('sensor.washer','door_lock') }}"
    washer_time_display:
      friendly_name: "Washer Time Display"
      value_template: >
        {% if is_state('sensor.washer_run_state', '-') %}
        {% elif is_state('sensor.washer_run_state', 'Standby') %}
        {% else %}
          {{ state_attr('sensor.washer', 'remain_time') }}
        {% endif %}
    dryer_time_display:
      friendly_name: "Dryer Time Display"
      value_template: >
        {% if is_state('sensor.dryer_run_state', '-') %}
        {% elif is_state('sensor.dryer_run_state', 'Standby') %}
        {% else %}
          {{ state_attr('sensor.dryer', 'remain_time') }}
        {% endif %}
    blank:
      value_template: ""
pretty sure I know the answer already… but just in case there is an easy way to infer from something else
I really want a door sensor for my LG washing machine. I currently use a separate wifi door sensor to trigger a reminder automation. if the drier is not running and washing completes, then send a notification. if the drier is running and the washing finishes then hold off sending the notification and send constant reminders once the drier finishes, there is also some things with zones, there is no point sending if we aren’t home etc.
the washing machine obviously has a door sensor built in, seems a waste its not sent via the app… plus the wife is getting annoyed when I tell her off for leaving the washing too long but its because she keeps ripping the door switch off with the washing basket and not sticking it back on
Thanks for your patience and help. I deleted everything and started over. I think part of my problem was I had originally named my entities “lg_washer” and “lg_dryer” and, even though I changed the names in yaml, something was tripping it up. So, I went back and changed the entities to match the original yaml code (“washer” and “dryer”) and it all works fine now.
Thanks again!
Looks good, but in your screenshot you’ve got part of the card yaml duplicated, hence the multiple displays under the graphic. It also looks like they are mixed up, and you have a washer and a dryer display under each. Unless you wanted it that way? But still an improvement, great work!
I just looked in entities, and sensors, and I don’t see a door open sensor that is exposed. Perhaps someone smarter than me could figure it out?
Hahaha. I’m glad I don’t do this for a living. Yes, a little bit of extra code at the bottom that I missed. I was so happy that I got the timer display to work, I didn’t even notice. Thanks.
Thanks for the helpful tips.
I just integrated my washer and it looks fantastic.
Only the display of the remaining time bothers me a bit. It is displayed in the format H:MM:SS. But the display of seconds is meaningless and is always 00. Is it possible to display the remaining time in the format H:MM?
ollo69,
I recently bought an LG dryer, model DLEX4000W . I used your integration. The sensors appear to work. Thank you !
One thing I’m wondering about is the Energy monitoring feature. This is something that LG advertises for this model and many others. In the Android app (LG Thinq), it is found under “Useful features” / “Energy usage”. However, it shows bar graphs and horizontal lines without any unit. Presumably, they are supposed to be kWh, but it’s impossible to say how many kWh each line represents - it appears to be context-dependent, ie. it changes depending on whether you are looking at the “Week”, “Month” or “Year” view. So, in fact, it is the opposite of useful.
Anyway, I was wondering if the energy consumed by the dryer (and other LG appliances) was something you could expose through the integration. If we could get the raw data, we could view it in HA properly in the “Energy” dashboard, as opposed to the broken LG Thinq app. Many thanks in advance !
I ended up putting an energy monitoring plug on my lg device to get accurate readings.
I would love to do that as well with my dryer, but I haven’t found an energy monitoring plug that will work with my dryer (240V 30 amp, 4-prong, NEMA 14-30P).
Wow, for that sort of circuit a CT clamp system like a Shelly EM would work.
