Hi
I have been using an in memory solution for the home assistant recorder, and ever since the latest update the logging has completely stopped working and when i attempted to restart HA I received the following message;
The system cannot restart because the configuration is not valid: Invalid config for [recorder]: In-memory SQLite database is not supported for dictionary value @ data['recorder']['db_url']. Got 'sqlite:///:memory:'. (See /config/configuration.yaml, line 18).
I use in-memory for the simple reason that I do not have a hard drive connected (nor am I interested in in this as a solution at all) and want to prevent the lifespan of the SD card being dramatically reduced with extraneous writes.
Is there any way to fix the in-memory logging so it behaves like before? or alternatively disable the recorder completely or send its output to null?
thanks
