In search of an Universal remote compatible with HA
As the title say, I’m in search of an universal remote control that could be used with HA. I have a few Logitech Hamony remote control, but no Harmony Hub, and all I can find in the documentation is about the Harmony Hub on home assistant.
I would like something to control my home theater room. Most equipments are in a closet, where a standard remote won’t be able to reach. I’m coming form a Control4 system, that I’m about to finish to push out of door and replace entirely with Home Assistant, and that’s probably the last step I need to figure out.
Thank you for your help
IR?
RF?
What frequency?
There is similar topic here every time I enter, did you do some search on this forum?
What are you wanting to control? Many AV devices have integrations. Others may have to go through something like Broadlink - Home Assistant
Hi guys, yea I admit my initial post was probably too generic to be helpful.
I mainly use an Apple TV gen 4 that can ne control with HA (the integration with Control4 was via IR) and a Samsung blue ray player that is IR only, as even if it can be connected via Ethernet I cannot find integration for it. It must be only for the smart features of its menu. I also have an Onkio receiver with Ethernet that can be controlled via HA that way (I still need to explore that path). I also would like to control the lighting in the room that are on Lutron Caseta and one light is with a SONOFF Zigbee control, all working in HA. I also want to control the screen and projector where I’m currently working to add to HA with a ESP32 and a relay. I’m close to completion on this, and very confident it will work soon!
Eventually, I would like to add the control the HVAC and my HI-FI home system that will likely be via IR and are located in the main room where I sit. So that should be the easiest part to deal with.
I searched on the forums, yes, but the terms universal, remote and control drove me in many wrong direction. Maybe I should have looked further or with different search terms.
And I forgot but I also have a Panasonic projector that I was already able to integrate with HA moving the serial cable from the Control4 and it can be easily controlled with some command line in HA.
This is is extremely customizable
I use knockoff alexa remotes (e.g. https://fr.aliexpress.com/item/1005008761551222.html) and an ESP32 with GitHub - dmamontov/esphome-blekeyboard: ESPHome BLE Keyboard in anticipation of the unevitable moment my dear Harmony will die…
I sadly gave up on My Harmony remotes. :cry:
Have an Elite and Ultimate
I thought that integration allowed home assistant to simulate Bluetooth keyboard key presses rather than a Bluetooth media remote key presses being received and sent to home assistant and interpreted for use in home assistant. Can you please clarify?
Well, no. First and foremost, it’s not a HA integration but an ESPHome component.
