Good Day All,
I am looking for reccomendations for a in-wall swich that is easily reflashable to Esphome that has Wifi and RF (or some other wireless way to switch the relay) with hardwired switch input.
Currently the lamps are 4 x 60W led battens switched off a single hard wired switch. The switch box on the wall only has a switched live so I’m intending on putting it in the ceiling where there is a neutral and live.
I am intending to install it in the relay in the ceiling box where there is a live & neutral.
What I need from the module:
The hard wired switch input shoud toggle the relay on change (high to low or low to hight) even when the wifi connection or homeassistant is down.
The RF input should be able to toggle the relay when the signal is received. (it can be any type of RF) even when the wifi connection or homeassistant is down. bonus if the RF switch is kenetic and doesn’t need batteries.
The relay should be able to be toggled using home assistant.
The RF/WIFI/DIrect wired switch should function similar to multi way switching. Where you can use the any comination to turn the lights on. e.g. you turn it on via home assistant and turn it off by with either RF or hard wired switch.
Ideally is capable of switching 16A or 20A but 10A will suffice.
Can opperate on 230Vac +/- 10%
I’ve found this switch. But to be honest I am not happy with the creapage and clearances on this module. Also it requires me to lift the Micro to flash it with ESPhome. If there is another switch with propert creapage and clearances I would be to lift the micro if needed.
Ideally the module will fit in this box.
Hopefully someone has come across something suitable.
Thanks,
