Hi there,
I am using the INA219A sensor to measure the current output from a water level sensor. The sensor I got has a range of 4-20mA.
I started by configuring the sensor as described in the ESPHome documents. The readings were quite good, but I wanted to get better accuracy and added the “max_voltage” and “max_current” instructions. As soon as I add the “max_current” instruction in the configuration, the output sensor values are totally off and far from the expected values. What did I do wrong?
Here is my configuration:
- platform: ina219
address: 0x40
shunt_resistance: 0.1 ohm
current:
power:
bus_voltage:
name: "INA219 Bus Voltage"
shunt_voltage:
name: "INA219 Shunt Voltage"
max_voltage: 25V
max_current: 0.02A
update_interval: 5s
Without the “max_*” statements the current reading is between 0.003 - 0.006A. With the statement the reading is 0.00012A - 0.00014A.
I checked the sensor, with a Multimeter and the reading is a steady 0.0041A, thus the sensor seems to be accurate.
