Not sure if that makes sense, but essentially I’d like to know if it’s possible to use “variable variable names” within nodes.
I’d like to set global.light.config.{{payload}} to some value.
This is so I don’t have to have one change node per light name, I’d have to then keep maintaining the flow when/if new lights are added/removed/renamed/etc.
Example Image: https://i.imgur.com/XVMYqLh.png
