I’ve been trying to separate the three common sensors I use on my devices, but without any success.
But I’m a newbie, at EspHome and yaml, so there’s a high possibility that I’m doing things wrong.
Lets say that I have a device with a configuration like:
dallas:
- pin: D2
# Common sensors
- platform: wifi_signal
- platform: uptime
- platform: adc
- platform: dallas
address: 0xEC00000B0EFA5E28
I would like to get the sensors between the comments out in a file and add it to all my devices. I’ve tried so far:
Creating the new file with the parent sensor
tag works, but does substitution, one or the other.
Tried:
dallas:
- pin: D2
<<: !include 10-common-sensors.yaml
- platform: dallas
Gives error for the - dallas
tag not allowed there.
mapping values are not allowed here
in “/root/config/custom-esp-ds18b20.yaml”, line 33, column 13:
- platform: dallas
Adding one indentation to the include throws another error
while parsing a block mapping
in “/root/config/custom-esp-ds18b20.yaml”, line 31, column 3:
expected , but found ‘-’
in “/root/config/custom-esp-ds18b20.yaml”, line 33, column 3:
- platform: dallas
Also tried:
dallas:
- pin: D2
- platform: dallas
But gives errors on all the contents of the file.
Failed config
platform: [source /root/config/10-common-sensors.yaml:1]
Component not found: platform.
wifi_signal
name: [source /root/config/10-common-sensors.yaml:2]Component not found: name.
ACS_RSSI
icon: [source /root/config/10-common-sensors.yaml:3]Component not found: icon.
mdi:wifi
update_interval: [source /root/config/10-common-sensors.yaml:4]Component not found: update_interval.
60s
filters: [source /root/config/10-common-sensors.yaml:6]Component not found: filters.
- delta: 1
unit_of_measurement: [source /root/config/10-common-sensors.yaml:11]Component not found: unit_of_measurement.
minutes
pin: [source /root/config/10-common-sensors.yaml:19]Component not found: pin.
VCC
Also tried multiple forms of indentation on the file (no, or one tab) to no avail.
Is there a way to accomplish this?
