Hi all,
I’m new with HA, but willing to learn, so I browsed and watched a couple of hours on YT.
I wanna start good, so splitting up my config is where I start and fail, so help is needed already.
my config end with:
group: !include groups.yaml
switch: !include switches.yaml
and in the same folder as configuration.yaml I have switches.yaml
in switches.yaml it I have the following:
- platform: buienradar
monitored_conditions:
- symbol
- humidity
- temperature
- windspeed
- pressure
When I restart my HA it states:
INVALID CONFIG
The following components and platforms could not be set up:
switch
Please check your config
What am I doing wrong here because the same happens when I try customize or camera, I’m planning on using these also.
Thx
Probably because switch is not a component.
Change it to sensors.yaml
silvrr
August 1, 2017, 2:28am
3
You are directing hass into you switches.yaml file and then have a sensor inside. If you want to have your sensors in a separate file make a sensors.yaml file for them. Then in your main config file add sensor: !include sensors.yaml
I made sensors.yaml. and pointed to there in the end of my config.
sensors: !include sensors.yaml
When restarting my HA it states:
Config Validating
Config error. See dev-info panel for details.
and
Invalid Config
sensors
----Config Validation is fixed, sensor was also in config removed and 1 error gone.-----
silvrr
August 1, 2017, 12:20pm
5
Do you have a sensor: in your sensors.yaml file? It is not needed. Each sensor can start with - platform with two spaces of indentation.
Read this page carefully.
That’s what I did.
So let’s start in the beginning:
Homeassistant:
customize: !include customize.yaml
in customize.yaml
sensor.fibaro_system_fgms001_motion_sensor_luminance:
friendly_name: Lux
Save -> restart and it doesn’t start
homeassistant (0 spaces)
customize: incl (2 spaces)
in customize.yaml
sensor.fibaro ( 2 spaces)
friendly_name (4 spaces)
Please follow this, it will help us help you.
Specifically code syntax
