I have a very needy NVME ssd from western digital and couldnt make it work anywhere but in windows, i managed to find the issue and now can boot ubuntu and use this ssd, but the only way to do it is including this in boot options: nvme_core.default_ps_max_latency_us=0
Since i cannot do the same for HAOS, would you please consider adding it to barebox bootloader for every future release ?
AI below:
Problem Statement
Many NVMe SSDs, especially OEM drives like the WDC SN520, have power state management (APST/PSM) issues in Linux. This causes HAOS to not detect the SSD at boot, preventing users from installing or running Home Assistant on certain hardware.
A well-known workaround in Linux is adding the kernel parameter:
This disables deep power-saving states and allows affected SSDs to function properly.
Proposed Solution
We request adding nvme_core.default_ps_max_latency_us=0 as:
- A default setting in HAOS (if there’s no negative impact).
- A configurable boot option in HAOS for users experiencing NVMe SSD issues.
Why This Is Important
- Some OEM NVMe SSDs (like WDC SN520) do not function correctly in HAOS without this setting.
- Users who install HAOS on mini PCs, NUCs, and custom hardware may face SSD detection failures.
- Other Linux distributions allow modifying kernel parameters, but HAOS is a locked appliance OS, making this impossible for users to fix themselves.
Alternative Workarounds (Not Ideal)
- Modifying the HAOS image manually before flashing (but updates reset this).
- Changing BIOS power settings (not all systems support this).
Request Summary
Add nvme_core.default_ps_max_latency_us=0as a boot parameter (if feasible).
Allow users to enable/disable NVMe power settings in HAOS config.
Thank you for considering this request! ![]()
