I’m trying to move my mqtt stuff out of configuration.yaml into it’s own file called mqtt.yaml, but I’m not having much luck.
When I run the Developer Tools → Check Configuration, it fails with the error:
Invalid config for [mqtt]: [name] is an invalid option for [mqtt]. Check: mqtt->mqtt->0->name. (See /config/configuration.yaml, line 15).
My configuration.yaml files looks like this:
# Loads default set of integrations. Do not remove.
default_config:
# Load frontend themes from the themes folder
frontend:
themes: !include_dir_merge_named themes
# Text to speech
tts:
- platform: google_translate
script: !include scripts.yaml
scene: !include scenes.yaml
mqtt: !include mqtt.yaml
notify:
- name: send_email
platform: smtp
encryption: starttls
verify_ssl: false
sender: [email protected]
sender_name: "Home Assistant"
recipient: [email protected]
server: mail.example.com
port: 587
username: ha
password: xxxxxx
I’ve tried naming the mqtt.yaml file to something else. I’ve tried moving the mqtt include stanza to the bottom of the file. Nothing works.
I’m on version:
Home Assistant 2023.10.5
Supervisor 2023.10.0
Operating System 11.0
Frontend 20231005.0 - latest
Any help would be appreciated.
