I have a number of views in their own files included from ui-lovelace.yaml which works flawless.
I’ve built most of them based on Button-Card
It works great with Templates placed in ui-Lovelace.yaml, but they are getting big and I want to move them to their own file.
Whatever I do, I can’t get it to work.
In ui-lovelace.yaml:
button_card_templates:
header:
and so on, works great, but when I change it to
- !include /settings/button_card_templates.yaml
and put the following in the button_card_templates.yaml
header:
styles:
There is no indentation before header: (I even tried with) and after that, the code follows the same structure as in ui-lovelace.yaml (cut+paste and changed the indentation so it lines up with the first template).
Whatever I do it seams to ignore everything written in the included file. I’m sure the file itself is found cause if there is an error in the path or filename i get an error that it cant be found.
I also tried to !include it from the included views with the same error
Nothing I do work, and I do not understand what I should do to make it.
petro
(Petro)
September 1, 2019, 11:43am
2
button_card_templates: !include /button_card_templates.yaml
May I ask another question about include?
I’m trying to include two files after each other in a view.
- type: custom:layout-card
layout: vertical
cards: !include family_tracker.yaml
Works fine, but if I want it to be followed by
!include lightoff.yaml, without any additional yaml code, I can’t understand how.
cards:
!include /config/lovelace/family_tracker.yaml
!include /config/lovelace/lightoff.yaml
Seams to be interpretated as one file.
cards:
- !include /config/lovelace/family_tracker.yaml
- !include /config/lovelace/lightoff.yaml
Then I get “No card type configured”
Found the error myself
When I used
`I had to use the following in the file
type: horizontal-stack
cards:
But when I used
cards:
- !include family_tracker.yaml
- !include lightoff.yaml
I had to the use following in the file
cards:
Kem
April 22, 2020, 5:38am
6
hi im confuse with the buttom template
where should i put this part in order to work i read the docs but English not been my first language did not helped ether thank you in advance
button_summary_picture:
show_state: false
show_label: true
show_name: false
show_entity_picture: true
aspect_ratio: 1/1
tap_action:
action: more-info
haptic: light
hold_action:
action: more-info
haptic: success
styles:
card:
- border-radius: 6px
- box-shadow: '0 4px 8px 0 rgba(0, 0, 0, 0.2), 0 6px 20px 0 rgba(0, 0, 0, 0.19)'
- background-color: ivory
- color: grey
- font-family: Helvetica
grid:
- position: relative
custom_fields:
time:
- position: absolute
- left: 30%
- top: 30%
- font-size: 14px
- font-weight: bold
- color: black
custom_header:
compact_mode: true
background: repeat
shadow: on
active_tab_color: '#07b379'
all_tabs_color: "#77807d"Preformatted text
petro
(Petro)
April 22, 2020, 7:30pm
7
show_state: false
show_label: true
show_name: false
aspect_ratio: 1/1
tap_action:
action: more-info
haptic: light
hold_action:
action: more-info
haptic: success
styles:
card:
- color: grey
grid:
custom_fields:
time:
- left: 30%
- top: 30%
- font-size: 14px
- font-weight: bold
- color: black
custom_header:
compact_mode: true
background: repeat
shadow: on
When adding button_card_templates: !include /button_card_templates.yaml
to the Lovelace raw editor it does not work. How do you add the !include directive into the raw editor?
Thanks,
Simon
Sirez
(Henrik)
June 17, 2020, 4:40pm
10
Yes, same problem here! I still found no solution for this. Anyone else maybe?
YAMLException: unknown tag !<!include>
petro
(Petro)
June 17, 2020, 6:56pm
11
you have to use yaml mode. Raw editor doesn’t have includes from what I can tell.
Thats why i can’nt get it working. So if i had a large button_template code i have to paste it in the raw editor?
petro
(Petro)
April 21, 2023, 2:39pm
13
You can’t use the raw editor with !includes. You have to use yaml mode, where your entire UI is generated by Yaml without using the UI at all.
exactly, but i do not want use yaml mode. so i can not use !include so i have to paste code in the raw editor itself, right?
petro
(Petro)
April 21, 2023, 3:11pm
15
Right, you can’t use the UI with includes so you have to paste the ‘included’ yaml into the raw editor with the appropriate spacing.
damn that will be a hell of a job. Cause I copy the code from the wheb but have to add 2 spaces to each line to get correct spacing.
Psi
January 19, 2024, 6:04pm
17
Sorry for the probably stupid question but where do I find the RAW editor ?
This gives me
Unable to parse YAML: YAMLException: unknown tag !<!include> (1:59) 1 | ... lude button_card_templates.yaml -----------------------------------------^ 2 | ... 3 | ...
!include cannot be used in a storage mode of a dashboard.
Psi
January 19, 2024, 7:08pm
19
Thx! I didn’t know about the two modes.
Does yaml mode mean I didn’t have any of the ui editing feature anymore?
In yaml-mode dashboard you cannot edit views/cards by a mouse))
