Inclusion not working after swap
I switched to HA with my zwave stick and i am unable to include any devices. The connected devices seem to work fine. So i bought a new stick, and that one can include devices in HA.
So i thought, must be the stick, which made me choose to use the NVM backup of my old stick to copy to the new stick, and now i got all the devices on the new stick but inclusion doesn’work any more.
Any tips would be very much appreciated.
Logfile is down below.
Kind regards,
Merlijn
I’m running haos on a rp3b btw.
Hope this is the right file, but i can only write 30000 characters.
2024-03-07T08:08:28.271Z DRIVER   all queues idle
2024-03-07T08:08:28.291Z CNTRLR   Starting inclusion process with strategy Default...
2024-03-07T08:08:28.294Z DRIVER   all queues busy
2024-03-07T08:08:28.297Z SERIAL » 0x0105004ac13041                                                     (7 bytes)
2024-03-07T08:08:28.299Z DRIVER » [REQ] [AddNodeToNetwork]
                                    node type:    Any
                                    high power:   true
                                    network wide: true
                                    callback id:  48
2024-03-07T08:08:28.301Z SERIAL « [ACK]        (0x06)
2024-03-07T08:08:28.352Z SERIAL « 0x0107004a3007000085                                                 (9 bytes)
2024-03-07T08:08:28.354Z SERIAL » [ACK]        (0x06)
2024-03-07T08:08:28.357Z DRIVER « [REQ] [AddNodeToNetwork]
                                    status:      Failed
                                    callback id: 48
2024-03-07T08:08:28.366Z CNTRLR   The controller is now ready to add nodes
2024-03-07T08:08:28.382Z DRIVER   all queues idle
2024-03-07T08:08:33.387Z DRIVER   all queues busy
2024-03-07T08:08:33.392Z SERIAL » 0x0103003bc7                                                         (5 bytes)
2024-03-07T08:08:33.393Z DRIVER » [REQ] [GetBackgroundRSSI]
2024-03-07T08:08:33.401Z SERIAL « [ACK]        (0x06)
2024-03-07T08:08:33.403Z SERIAL « 0x0105013ba8aac2                                                     (7 bytes)
2024-03-07T08:08:33.405Z SERIAL » [ACK]        (0x06)
2024-03-07T08:08:33.411Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -88 dBm
                                    channel 1: -86 dBm
2024-03-07T08:08:33.414Z DRIVER   all queues idle
2024-03-07T08:08:58.291Z CNTRLR   stopping inclusion process...
2024-03-07T08:08:58.304Z DRIVER   all queues busy
2024-03-07T08:08:58.308Z SERIAL » 0x0105004ac53144                                                     (7 bytes)
2024-03-07T08:08:58.309Z DRIVER » [REQ] [AddNodeToNetwork]
                                    action:       Stop
                                    high power:   true
                                    network wide: true
                                    callback id:  49
2024-03-07T08:08:58.313Z SERIAL « [ACK]        (0x06)
2024-03-07T08:08:58.366Z SERIAL « 0x0107004a3106000085                                                 (9 bytes)
2024-03-07T08:08:58.369Z SERIAL » [ACK]        (0x06)
2024-03-07T08:08:58.374Z DRIVER « [REQ] [AddNodeToNetwork]
                                    status:      Done
                                    callback id: 49
2024-03-07T08:08:58.377Z CNTRLR   The inclusion process was stopped
2024-03-07T08:08:58.385Z DRIVER   all queues idle
2024-03-07T08:09:03.389Z DRIVER   all queues busy
2024-03-07T08:09:03.395Z SERIAL » 0x0103003bc7                                                         (5 bytes)
2024-03-07T08:09:03.396Z DRIVER » [REQ] [GetBackgroundRSSI]
2024-03-07T08:09:03.399Z SERIAL « [ACK]        (0x06)
2024-03-07T08:09:03.401Z SERIAL « 0x0105013ba8a2ca                                                     (7 bytes)
2024-03-07T08:09:03.403Z SERIAL » [ACK]        (0x06)
2024-03-07T08:09:03.407Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -88 dBm
                                    channel 1: -94 dBm
2024-03-07T08:09:03.415Z DRIVER   all queues idle
2024-03-07T08:09:33.392Z DRIVER   all queues busy
2024-03-07T08:09:33.403Z SERIAL » 0x0103003bc7                                                         (5 bytes)
2024-03-07T08:09:33.405Z DRIVER » [REQ] [GetBackgroundRSSI]
2024-03-07T08:09:33.410Z SERIAL « [ACK]        (0x06)
2024-03-07T08:09:33.413Z SERIAL « 0x0105013ba8a2ca                                                     (7 bytes)
2024-03-07T08:09:33.415Z SERIAL » [ACK]        (0x06)
2024-03-07T08:09:33.420Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -88 dBm
                                    channel 1: -94 dBm
2024-03-07T08:09:33.425Z DRIVER   all queues idle
2024-03-07T08:10:03.391Z DRIVER   all queues busy
2024-03-07T08:10:03.397Z SERIAL » 0x0103003bc7                                                         (5 bytes)
2024-03-07T08:10:03.398Z DRIVER » [REQ] [GetBackgroundRSSI]
2024-03-07T08:10:03.401Z SERIAL « [ACK]        (0x06)
2024-03-07T08:10:03.404Z SERIAL « 0x0105013ba8a5cd                                                     (7 bytes)
2024-03-07T08:10:03.406Z SERIAL » [ACK]        (0x06)
2024-03-07T08:10:03.411Z DRIVER « [RES] [GetBackgroundRSSI]
                                    channel 0: -88 dBm
                                    channel 1: -91 dBm
2024-03-07T08:10:03.415Z DRIVER   all queues idle
I found out that hard resetting the zwave stick does solve the inclusion problem. But i really want to keep my added devices, because the amount of devices will make it one hell of a job to remove all of the devices in order to include them.
Anyone that has an idea of where to look for?
How much RAM do you have? I ask because I’ve seen other posts of this forum that suggest that model may not have sufficient resources to run ha and zwave.
Thanks for replying! I have 1gb RAM.
