Incompatable engine error
Hey all. In trying to install a new node via the manage pallete I get an incompatable error message. It says for Google calender. I removed the google calender nodes and did a restart but still same error. Do I have to delete from the disk or something else? I did an upgrade of HA and all associated bits and bobs so just sorting some errors out.
npm WARN config production Use --omit=dev instead.
npm ERR! code EBADENGINE
npm ERR! engine Unsupported engine
npm ERR! engine Not compatible with your version of node/npm: [email protected]
npm ERR! notsup Not compatible with your version of node/npm: [email protected]
npm ERR! notsup Required: {“node”:"^0.12.7"}
npm ERR! notsup Actual: {“npm”:“8.10.0”,“node”:“v16.16.0”}
npm ERR! A complete log of this run can be found in:
npm ERR! /root/.npm/_logs/2022-07-30T07_25_55_252Z-debug-0.log
Is almost 7 years since the node was updated. There are newer options.
Thanks Mikefila. I dont use it and have removed it from the pallete but I still get the above error. Do I need to delete it from the drive or something else?
