I use the OpenAI Conversation integration to ask ChatGPT questions about sensors, e.g. about air quality. For this purpose, I have adopted the configuration from here, with which the entities are transmitted to OpenAI: OpenAI Home-Assistant Together At last
The 3.5 Turbo model is used. In principle, it works, but some of the answers are incorrect.
Example: If I ask about the air quality in the living room based on CO2 and TVOC values, I get a detailed answer. But sometimes the values are not correct. After asking 2-3 times, I sometimes get the right answer. I also get the same thing when I ask about the status of open doors. ChatGPT then also says that a certain door is open even though it is closed. If I then ask “Are you sure?”, it sometimes corrects itself, but not always.
Does anyone have any idea what the problem is? Hallucinations? Is GPT3.5-Turbo no good?
