Incorrect sensor readings HS110... Anyone have similar?
I noticed today that my watt reading (which is pretty accurate when checking against different devices) is different to the Amps*V calculation.
I’ve setup 3 Amp sensors:
Raw sensor,
Watts/Volts,
Raw Sensor with a 0.2 offset (it had a 0.2a difference at my PCs normal load.
See the album here: The calculated and the RAW output match when the load is high but not when it’s low.
Could TP Link use a curve fitting bias to the watt measurement (I guess the amps aren’t super accurate at low load???).
