I’ve created an esphome sensor that has a temperature entity. What is being reported by the actual entity is in degF. In addition, if I display an entity card, it displays it as degF. However, when I display it as a chart, the “value” is degF, but the units in the upper corner are showing as degC. So, not only does it not show the correct unit, it prevents the overlay of other chars in the same card. Any thoughts on what to check? There are no errors reported in the log that I can see.
