Incorrect values on energy dashboard
Hello, I need your help to understand how Home Assistant manages energy statistics. I have 1 shelly em with 2 clamp meters. 1 clamp measures the energy taken and fed into the network directly from the meter, while the other is connected to the main switch of the house and therefore controls the real consumption of the house. of the HA dashboard I also have sensors that come from the photovoltaic that measure the energy to and from the batteries and the total production. Now the values ​​that HA shows on home consumption are not true and I can’t understand how HA generates them given that it has to collect the data from the shelly. I attach an image where you can see that only the data coming from the network corresponds. the same sensors are used in both cards.
Thank you all
