Hello everyone,
My first post in that community and first of all, thanks a lot for this great piece of software. I have been using it for about two years now and it has been really solid.
I have a bunch of Kerui D026 door sensors that I integrated a few months back (early 2020). One of them died and I replaced it after having upgraded to the latest HA release (2020-12.1). Unfortunately, despite having exactly the same configuration as for my working sensors, this one does not seem to pick up my device configuration properly.
Here is an example of a working sensor, which was successfully added months ago:
rfxtrx:
device: /dev/serial/by-id/usb-RFXCOM_RFXtrx433_A1YQBVQ2-if00-port0
devices:
09130017747eae013d60:
device_class: opening
data_bits: 4
command_on: 0xe
command_off: 0x7
off_delay:
seconds: 10
0913001c747eab013d70:
device_class: problem
off_delay:
seconds: 5
The new sensor has exactly the same configuration but is not recognised as a ‘opening’ type, but instead as a generic ‘on/off’ binary sensor. It also does not respect the off_delay, which means it stays forever active. As such, it is therefore useless.
Maybe some changes in the rfxcom integration performed last July could be the cause, but it is hard to tell without being a developer on the project.
Any help would be welcome, cheers!
