Increase an image size
Hi, I’m new to configuring the home assistant, I want to place an image but it’s too small, can anyone explain how I can change the size. Thanks
Might need a little more information: Are you referring to an image on a picture elements card on a dashboard?
First, welcome to the forum! I’m fairly new as well but have been playing with this exact card. i think you only have limited options, and i ended up breaking my floorplan into smaller pieces (basically by room). there’s an option (which i didn’t end up liking) to basically full-screen it by incorporating the following
panel: true
See the link below for more info on that. i believe you have to add that code before adding the element card
https://community.home-assistant.io/t/lovelace-sizing-the-main-image-of-picture-elements/76546/4
Hey Jorel, thanks for the reply, the method you said didn’t fixed my problem, I end up with the solution in the video below, its make the picture bigger but for now its good for me.
