hello
i am setting up a dashboard for my nest hub, and would like to increase the size of the thermostat card to fill the screen. is there any way to do that?
cheers
hello
cheers
Set it as a panel.
wdym as a panel
i thought panel card only works if you have a single card in the dashboard. i set this in the tabbed-card and get an error stating Unknown type encountered: panel
- card:
type: panel
cards:
- type: thermostat
entity: climate.thermostat
attributes:
label: Thermostat
So you want other cards, but you want thermostat to fill the screen? Where are the other cards going to fit then?
sorry, i meant fill the blank area in the screen
The whole intention is not clear. Post the whole card then.
Assume there is a tabbed card - the 1st tab is a thermostat, other tabs keep other cards.
If you need the whole tabbed card to occupy the screen area - define “type: panel” for the view, the tabbed card should be the only card. Then the thermostat will also occupy the whole sceeen - as well as cards on other tabs.
But you cannot define a panel-view-like for one tab only (unless you use a custom layout-card which may allow you to mimic different types of a view).
Everything is written above is for a case w/o any other cards except tabbed-card.
But here you also have some kind of vertical stack.
So, your goal MAY be achieved by:
i just want to increase the size of the thermostat card to fill the remainder of the screen on the nest, essentially fill the rest of the screenshot i attached in the op. i do not want it to fill the whole nest screen size.
- title: Home
type: custom:layout-card
layout_type: custom:grid-layout
layout:
grid-template-columns: 40% 60%
grid-template-areas: |
"left right"
cards:
- type: vertical-stack
cards:
- type: custom:clock-weather-card
entity: weather.pirateweather
sun_entity: sun.sun
temperature_sensor: sensor.outdoor_temp
weather_icon_type: line
animated_icon: true
forecast_days: 1
locale: en-US
time_format: 12
date_pattern: MMM do
use_browser_time: true
- type: custom:stack-in-card
cards:
- type: custom:mushroom-title-card
title: bedroom
- type: horizontal-stack
cards:
- type: custom:mushroom-entity-card
icon_color: blue
primary_info: name
secondary_info: none
entity: switch.lamp
icon: mdi:desk-lamp
tap_action:
action: toggle
entity: switch.fan
primary_info: name
icon: mdi:fan
icon_color: blue
tap_action:
action: toggle
cards:
title: living room
cards:
icon_color: blue
primary_info: name
entity: switch.globe_lamp_2
icon: mdi:floor-lamp-torchiere
tap_action:
action: toggle
entity: switch.egpu
primary_info: name
icon: mdi:expansion-card
icon_color: blue
tap_action:
action: toggle
- type: custom:mushroom-media-player-card
entity: media_player.android_tv_192_168_1_237
tap_action:
action: toggle
primary_info: name
use_media_info: true
secondary_info: state
media_controls: []
volume_controls: []
collapsible_controls: false
hold_action:
action: more-info
view_layout:
grid-area: left
mode: vertical
cards:
- type: custom:tabbed-card
styles:
'--mdc-tab-text-label-color-default': rgba(225, 225, 225, 0.8)
view_layout:
grid-area: main2
tabs:
- card:
cards:
view_layout:
grid-area: SUB3
entity: media_player.spotify_evanmumma1
fill_container: true
volume_controls:
- volume_mute
- volume_set
- volume_buttons
media_controls: []
show_volume_level: true
use_media_info: false
layout: horizontal
icon_type: none
primary_info: none
- type: media-control
theme: Graphite
view_layout:
grid-area: SUB1
view_layout:
grid-area: SUB2
cards:
entity: switch.amplifier_2
icon: mdi:amplifier
icon_color: light-blue
primary_info: name
tap_action:
action: call-service
service: automation.trigger
entity_id: automation.toggle_amp
skip_condition: false
entity: switch.virtual_soundbar
primary_info: name
tap_action:
entity_id: automation.spotify_soundbar
hold_action:
action: none
icon_color: blue
double_tap_action:
action: none
icon: mdi:soundbar
layout:
grid-template-columns: 0% 66% 2% 31%
grid-template-rows: 15px 350px
"SUB4 SUB4 SUB4 SUB4"
"SUB1 SUB1 SUB1 SUB1"
". SUB2 SUB2 SUB2"
"SUB3 SUB3 SUB3 SUB3"
view_layout:
grid-area: main2
attributes:
label: Media
- card:
type: thermostat
attributes:
label: Thermostat
- card:
mode: vertical
cards:
- type: custom:hourly-weather
num_segments: 18
name: Next 18 hours
title: Next 10 days
sun_entity: sun.sun
hide_today_section: true
forecast_days: 10
locale: en-US
time_format: 12
attributes:
label: Weather
- card:
mode: vertical
cards:
- type: custom:flower-card
entity: plant.mass_cane
show_bars:
- illuminance
- moisture
- conductivity
- temperature
battery_sensor: sensor.plant_sensor_5326_battery
entity: plant.golden_pothos
show_bars:
- illuminance
- moisture
- conductivity
- temperature
battery_sensor: sensor.plant_sensor_61b2_battery
entity: plant.snake_plant
show_bars:
- illuminance
- moisture
- conductivity
- temperature
battery_sensor: sensor.plant_sensor_63a3_battery
attributes:
label: Plants
