Finally got this set up how I like in the end:
For anyone else struggling with it I am using this .js file for the custom alarm card:
class AlarmControlPanelCard extends HTMLElement {
constructor() {
super();
this.attachShadow({ mode: 'open' });
this._icons = {
'armed_away': 'mdi:shield-lock',
'armed_custom_bypass': 'mdi:security',
'armed_home': 'mdi:shield-home',
'armed_night': 'mdi:shield-home',
'disarmed': 'mdi:shield-check',
'pending': 'mdi:shield-outline',
'triggered': 'hass:bell-ring',
set hass(hass) {
const entity = hass.states[this._config.entity];
if (entity) {
this.myhass = hass;
if(!this.shadowRoot.lastChild) {
this._createCard(entity);
if (entity.state != this._state) {
this._state = entity.state;
this._updateCardContent(entity);
_createCard(entity) {
const config = this._config;
const card = document.createElement('ha-card');
card.innerHTML = `
${this._iconLabel()}
${config.title ? '<div id="state-text"></div>' : ''}
const content = document.createElement('div');
content.id = "content";
content.style.display = config.auto_hide ? 'none' : '';
content.innerHTML = `
${this._actionButtons()}
${entity.attributes.code_format ?
`<paper-input label='${this._label("ui.card.alarm_control_panel.code")}'
type="text"></paper-input>` : ''}
${this._keypad(entity)}
card.appendChild(this._style(config.style, entity));
card.appendChild(content);
this.shadowRoot.appendChild(card);
this._setupInput();
this._setupKeypad();
this._setupActions();
connectedCallback() {
setConfig(config) {
if (!config.entity || config.entity.split(".")[0] !== "alarm_control_panel") {
throw new Error('Please specify an entity from alarm_control_panel domain.');
if (config.auto_enter) {
if (!config.auto_enter.code_length || !config.auto_enter.arm_action) {
throw new
Error('Specify both code_length and arm_action when using auto_enter.');
this._arm_action = config.auto_enter.arm_action;
if (!config.states) config.states = ['arm_away', 'arm_home'];
if (!config.scale) config.scale = '15px';
this._config = Object.assign({}, config);
const root = this.shadowRoot;
if (root.lastChild) root.removeChild(root.lastChild);
_updateCardContent(entity) {
const card = root.lastChild;
const state_str = "state.alarm_control_panel." + this._state;
if (config.title) {
card.header = config.title;
root.getElementById("state-text").innerHTML = this._label(state_str);
root.getElementById("state-text").className = `state ${this._state}`;
} else {
card.header = this._label(state_str);
root.getElementById("state-icon").setAttribute("icon",
this._icons[this._state] || 'mdi:shield-outline');
root.getElementById("badge-icon").className = this._state;
var iconText = this._stateIconLabel(this._state);
if (iconText === "") {
root.getElementById("icon-label").style.display = "none";
} else {
root.getElementById("icon-label").style.display = "";
if (iconText.length > 5) {
root.getElementById("icon-label").className = "label big";
} else {
root.getElementById("icon-label").className = "label";
root.getElementById("icon-text").innerHTML = iconText;
const armVisible = (this._state === 'disarmed');
root.getElementById("arm-actions").style.display = armVisible ? "" : "none";
root.getElementById("disarm-actions").style.display = armVisible ? "none" : "";
_actionButtons() {
return `
<div id="arm-actions" class="actions">
${this._config.states.map(el => `${this._actionButton(el)}`).join('')}
</div>
<div id="disarm-actions" class="actions">
${this._actionButton('disarm')}
</div>`;
_stateIconLabel(state) {
const stateLabel = state.split("_").pop();
return stateLabel === "disarmed" ||
stateLabel === "triggered" ||
!stateLabel
: stateLabel;
_iconLabel() {
return `
<ha-label-badge-icon id="badge-icon">
<div class="badge-container" id="badge-container">
<div class="label-badge" id="badge">
<div class="value">
<ha-icon id="state-icon"/>
</div>
<div class="label" id="icon-label">
<span id="icon-text"/>
</div>
</div>
</div>
</ha-label-badge-icon>`;
_actionButton(state) {
return `<mwc-button outlined id="${state}">
${this._label("ui.card.alarm_control_panel." + state)}</mwc-button>`;
_setupActions() {
const card = this.shadowRoot.lastChild;
if (config.auto_hide) {
root.getElementById("badge-icon").addEventListener('click', event => {
var content = root.getElementById("content");
if (content.style.display === 'none') {
content.style.display = '';
} else {
content.style.display = 'none';
card.querySelectorAll(".actions mwc-button").forEach(element => {
element.classList.remove('autoarm');
if (element.id === this._arm_action || element.id === 'disarm') {
element.classList.add('autoarm');
element.addEventListener('click', event => {
if (element.id !== 'disarm') this._arm_action = element.id;
} else {
const input = card.querySelector('paper-input');
const value = input ? input.value : '';
this._callService(element.id, value);
_callService(service, code) {
const input = this.shadowRoot.lastChild.querySelector("paper-input");
this.myhass.callService('alarm_control_panel', `alarm_${service}`, {
entity_id: this._config.entity,
code: code,
if (input) input.value = '';
_setupInput() {
if (this._config.auto_enter) {
input.addEventListener('input', event => { this._autoEnter() })
_setupKeypad() {
const input = root.lastChild.querySelector('paper-input');
root.querySelectorAll(".pad mwc-button").forEach(element => {
if (element.getAttribute('value') ===
this._label("ui.card.alarm_control_panel.clear_code")) {
input.value = '';
} else {
input.value += element.getAttribute('value');
this._autoEnter();
_autoEnter() {
const code = card.querySelector("paper-input").value;
if (code.length == config.auto_enter.code_length) {
const service = card.querySelector(".actions .autoarm").id;
this._callService(service, code);
_keypad(entity) {
if (this._config.hide_keypad || !entity.attributes.code_format) return '';
return `
<div class="pad">
<div>
${this._keypadButton("1", "")}
${this._keypadButton("4", "GHI")}
${this._keypadButton("7", "PQRS")}
</div>
<div>
${this._keypadButton("2", "ABC")}
${this._keypadButton("5", "JKL")}
${this._keypadButton("8", "TUV")}
${this._keypadButton("0", "")}
</div>
<div>
${this._keypadButton("3", "DEF")}
${this._keypadButton("6", "MNO")}
${this._keypadButton("9", "WXYZ")}
${this._keypadButton(this._label("ui.card.alarm_control_panel.clear_code"), "")}
</div>
</div>`
_keypadButton(button, alpha) {
let letterHTML = '';
if (this._config.display_letters) {
letterHTML = `<div class='alpha'>${alpha}</div>`
return `<mwc-button value="${button}">${button}${letterHTML}
</mwc-button>`;
_style(icon_style, entity) {
const style = document.createElement('style');
style.textContent = `
ha-card {
${(this._config.hide_keypad ||
!entity.attributes.code_format) ? 'padding-bottom: 16px;' : '' }
position: relative;
--alarm-color-disarmed: var(--label-badge-green);
--alarm-color-pending: var(--label-badge-yellow);
--alarm-color-triggered: var(--label-badge-red);
--alarm-color-armed: var(--label-badge-red);
--alarm-color-autoarm: rgba(0, 153, 255, .1);
--alarm-state-color: var(--alarm-color-armed);
--base-unit: ${this._config.scale};
font-size: calc(var(--base-unit) * 1.5);
${icon_style}
ha-icon {
color: var(--alarm-state-color);
width: calc(var(--base-unit) * 3);
height: calc(var(--base-unit) * 3);
ha-label-badge-icon {
--ha-label-badge-color: var(--alarm-state-color);
--label-badge-text-color: var(--alarm-state-color);
--label-badge-background-color: var(--paper-card-background-color);
position: absolute;
right: 12px;
top: 12px;
margin-bottom: calc(var(--base-unit));
.badge-container {
display: inline-block;
text-align: center;
vertical-align: top;
.label-badge {
position: relative;
display: block;
margin: 0 auto;
width: var(--ha-label-badge-size, 2.5em);
text-align: center;
height: var(--ha-label-badge-size, 2.5em);
line-height: var(--ha-label-badge-size, 2.5em);
font-size: calc(var(--base-unit) * 1.6);
border-radius: 50%;
border: 0.15em solid var(--ha-label-badge-color, var(--primary-color));
color: var(--label-badge-text-color, rgb(76, 76, 76));
white-space: nowrap;
background-color: var(--label-badge-background-color, white);
background-size: cover;
transition: border 0.3s ease-in-out;
.label-badge .value {
font-size: 90%;
overflow: hidden;
text-overflow: ellipsis;
.label-badge .value.big {
font-size: 70%;
.label-badge .label {
position: absolute;
bottom: -1em;
/* Make the label as wide as container+border. (parent_borderwidth / font-size) */
left: -0.2em;
right: -0.2em;
line-height: 1em;
font-size: 0.5em;
.label-badge .label span {
box-sizing: border-box;
max-width: 100%;
background-color: var(--ha-label-badge-color, var(--primary-color));
color: var(--ha-label-badge-label-color, white);
border-radius: 1em;
padding: 9% 16% 8% 16%; /* mostly apitalized text, not much descenders => bit more top margin */
font-weight: 500;
overflow: hidden;
text-transform: uppercase;
transition: background-color 0.3s ease-in-out;
text-transform: var(--ha-label-badge-label-text-transform, uppercase);
.label-badge .label.big span {
font-size: 90%;
padding: 10% 12% 7% 12%; /* push smaller text a bit down to center vertically */
.badge-container .title {
margin-top: 1em;
font-size: var(--ha-label-badge-title-font-size, 0.9em);
width: var(--ha-label-badge-title-width, 5em);
font-weight: var(--ha-label-badge-title-font-weight, 400);
overflow: hidden;
line-height: normal;
.disarmed {
--alarm-state-color: var(--alarm-color-disarmed);
.triggered {
--alarm-state-color: var(--alarm-color-triggered);
animation: pulse 1s infinite;
.arming {
--alarm-state-color: var(--alarm-color-pending);
.pending {
@keyframes pulse {
0% {
100% {
--ha-label-badge-color: rgba(255, 153, 0, 0.3);
paper-input {
margin-top: 0px;;
margin-left: auto;
margin-right: auto;
margin-bottom: 0px;
max-width: 200px;
height: fit-content;
mwc-button {
margin-right: 5px;
margin-left: 5px;
justify-content: center;
.state {
margin-left: calc(var(--base-unit) * 1.2);
font-size: calc(var(--base-unit) * 1.2);
position: relative;
bottom: 16px;
animation: none;
.pad {
display: flex;
margin-left: 40px;
margin-right: 40px;
padding: 10px;
.pad div {
display: flex;
flex-direction: column;
margin-top: 0px;
margin-left: auto;
margin-right: auto;
margin-bottom: auto;
padding: 0px;
.pad mwc-button {
min-height: calc(var(--base-unit) * 4);
min-width: calc(var(--base-unit) * 5);
margin-top: 10px;
margin-bottom: 10px;
padding: 5px;
font-size: 22pt;
.pad mwc-button button.mdc-button.mdc-button--dense {
font-size: 28pt;
.actions {
display: flex;
flex-wrap: wrap;
margin-top: calc(var(--base-unit) * 0.5);
.actions .autoarm {
background: var(--alarm-color-autoarm);
mwc-button#disarm {
color: red;
.actions mwc-button {
min-height: calc(var(--base-unit) * 2.5);
min-width: calc(var(--base-unit) * 8);
.alpha {
position: absolute;
text-align: center;
bottom: calc(var(--base-unit) * 0.1);
color: var(--secondary-text-color);
return style;
_label(label, default_label=undefined) {
// Just show "raw" label; useful when want to see underlying const
// so you can define your own label.
if (this._config.show_label_ids) return label;
if (this._config.labels && this._config.labels[label])
return this._config.labels[label];
const lang = this.myhass.selectedLanguage || this.myhass.language;
const translations = this.myhass.resources[lang];
if (translations && translations[label]) return translations[label];
if (default_label) return default_label;
// If all else fails then pretify the passed in label const
const last_bit = label.split('.').pop();
return last_bit.split('_').join(' ').replace(/^\w/, c => c.toUpperCase());
getCardSize() {
return 1;
customElements.define('alarm_control_panel-card', AlarmControlPanelCard);
and then styling it using the card-mod addon with this CSS:
card_icon: 'mdi:bell'
entity: alarm_control_panel.home_alarm
scale: 15px;
style:
ha-card {
--mdc-theme-primary: var(--primary-text-color);
div.pad {
margin-left: 20px;
margin-right: 20px;
div.pad mwc-button:
:host {
margin-top: 10px;
padding: 5px;
border: solid;
border-width: 3px;
border-radius: 25%;
border-color: var(--primary-text-color);
button {
font-size: 24px !important;
margin-top: 12px;
'div.pad mwc-button[value*="Clear"]':
button {
font-size: 16px !important;
margin-top: 12px;
--mdc-theme-primary: green;
title: Title
type: 'custom:alarm_control_panel-card'
