Increase font size of numbers on manual alarm panel keypad
This looks awesome. I’m looking forward to setting up a konnected.io system and running this on a Fire HD 10 mounted at my front entrance.
Thanks!
Sorry for the delay- I have updated the card to work properly with auto_enter.
Still not in HACS- please just grab it from GitHub - jcooper-korg/AlarmPanel
-John
John-
I’m still using this and appreciate it just working. I just refreshed with your new source and finally integrated the timer. However, I’m a bit baffled with the yaml for:
auto_enter: (optional object). you must also specify code_length and arm_action.....
Might I suggest you update your example card with the right way use it?
Also - wrt HACS. Is there something I can assist you with on that? While I’ve not done the steps I could take a whack and share back to you if that helps. I’d like to see others get exposed to this… https://hacs.xyz/docs/publish/start
Hi Dave,
I added an AlarmLovelaceDashboardWithAutoEnter.yaml to my example configs. Tl;dir: do something like this in your card config:
auto_enter:
  code_length: 4
  arm_action: arm_away
That says that after entering 4 digits, it’ll auto disarm or arm away.
Thanks for offering to help with HACS. I have to rename my repo and the js files, and write some json. I’ll try to get to it soon and you can help me test it.
Cheers,
-John
Hello @johnplanetz I hope all is well with you.
I’ve been using your custom component for some time now. I’m not sure if its a recent problem or if it’s always been this way. I noticed when the alarm panel is collapsed, and the alarm is in a pending state (pre-triggered), I’m unable to expand the panel to type the code to disarm. Any idea’s what may cause this? I’ve tested on my fire tablet, phone and laptop, they all behave the same way. If the panel is already expanded when the alarm is pending, I’m able to enter the code to disarm before it triggers.
Any help is appreciated. Thank you in advance.
This is my lovelace:
type: custom:alarm_control_panel-card
entity: alarm_control_panel.home_alarm
show_countdown_timer: true
auto_hide: true
auto_enter:
  code_length: 4
  arm_action: disarm
confirm_entities:
  - binary_sensor.front_door
  - binary_sensor.patio_door
labels:
  ui.card.alarm_control_panel.arm_away: AWAY
  ui.card.alarm_control_panel.arm_home: HOME
  ui.card.alarm_control_panel.clear_code: CLEAR
  ui.card.alarm_control_panel.disarm: DISARM
scale: 14px
states:
  - arm_home
  - arm_away
style:
    button {
        background-color: steelblue !important;
E’ possibile rinominare la scritta all’interno del badge?
I think you could modify the logic in _stateIconLabel(state), in alarm_control_panel-card.js to translate from the entity.state text to your own text.
-John
John,
I have been looking how to configure an alarm card dashboard that optimally uses the screen space of a Sonoff NSpanel Pro (4 inch, 480*480px). Your custom dashboard, when combined with kiosk mode to hide the header bar, almost yields what I am looking for. Alas, the keypad does not fully show - only the top part of the last row of keys fits on screen without scrolling.
I would like to avoid having to scale down the elements or font sizes as this reduces the comfort when typing in an alarm code on a rather small screen.
Is there a way to either
  • move the box with code into the title bar?
  • integrate the dots showing the number of digits entered into either the clear or disarm button?
  • move the box with code underneath the box?
As a sidenote, when typing in a code, the dots may want to replace the word ‘Code’ rather than being added right below.
Thanks for sharing your efforts.
