Increase Fritz DECT polling intervall for power metering
I´m using a Fritz DECT 210 for measuring my balcony PV, everything works fine in HA so far. In the past, I used also the DECT!Read Simple UNI for additional polling so that HA gets the power consumption data every 30 seconds (and not only 2 minutes as per default). With the last Fritz OS-update, it seems that this “workaround” doesn´t work anymore.
Are there other users here with the same problem/constellation or does anyone have a simple solution for this, so that I get the data in a higher frequency?
Thanks!
Greetings from Germany,
Philip
Hi, i don’t know DECT!Read Simple UNI. I solved the problem with a trigger automation. Turn “on” the Fritz dect every “x” seconds.
Blockquote
description: “”
mode: single
  • platform: time_pattern
    seconds: “2”
    condition:
  • type: turn_on
    device_id: ################################
    entity_id: ################################
    domain: switch
Blockquote
Perhaps antoher possibilty is the service: homeassistant.update_entity.
Blockquote
description: “”
mode: single
    seconds: “2”
    condition:
  • service: homeassistant.update_entity
    entity_id: sensor.fritz_dect_200
    data: {}
`> Blockquote
Greetings from berlin (i know my englisch is bad. sorry)
Matze
Hi Matze,
thanks, it seems that powering on the switch device regurlarly did the trick :slight_smile:
Just updating the entitity didn´t work…
Danke :slight_smile:
