It would be great to set the number of traces to save per automation or script. A default value could be used with the ability to set a higher value if necessary.
This would allow for increased debugging ability by having more traces to examine.
You can do this already, look here:
Is this per automation or globally?
As per the document I linked:
The last 5 traces are recorded for all automations. It is possible to change this by adding the following code to your automation.
Therefore all automations and scripts have a default of 5 traces and you can set more per automation as the document says.
Note however setting it too high is a waste of time as when home assistant restarts all stored traces are lost anyway.
Perfect thank you.
I’m interested in this too. Could someone show a larger piece of yaml code that shows where in the automation this trace: goes.
Just add anywhere in the automation such as the end
For example after mode…
mode: single
trace:
stored_traces: 10
Perfect. Thanks.
