Increase the clickable area of a card
I have a card with a custom mushroom-entity-card that I’m using to toggle the kettle on and off on one of my dashboards. The trouble is, the tablet is small and the default size of the icons is even smaller. So I’ve increased the size of the icon. If I make it any bigger, the icon overlaps the text which obvioiusly isn’t great. So my options are:
  • remove the title of the card and increase the icon even bigger, or
  • figure out a way to make the area outside of the icon but inside the card clickable
Any ideas would be appreciated! Here’s my yaml and a screnshot of the card below
Screenshot-6
type: vertical-stack
cards:
    - type: custom:mushroom-entity-card
      fill_container: true
      layout: vertical
      tap_action:
        action: toggle
      entity: switch.smart_kettle_keep_warm
      icon: mdi:kettle
      card_mod:
        style: |
          :host {
            --mush-icon-symbol-size: 2em;
did you find out ?
Nah. I ended up using the built-in button card which has the option to change the icon size via the UI. I recommend checking it out. Much cleaner and the entire card is clickable
