Please format your code properly using the </> button so we can see the indenting. Also please detail how you have created your floorplan including what software you used.
When you use Inkscape have you made sure that there isn’t blank space surrounding your SVG? In the following picture I have moved my SVG elements so you can see the white rectangle which is the actual SVG size. You adjust this size as shown in the dialog box on the right
