klogg
(Klogg)
September 11, 2018, 10:55pm
1
So, I want to add one to an input_boolean
every time a binary_sensor
with (nearly) the same name has a state change. I’ve been round in circles with this and ended up with the following which doesn’t seem to work but I am sure is close.
Because I’m using trigger.entity_id
it is hard to find a way to test this in the developer tools.
- alias: Increment sensor activation count
- platform: state
entity_id:
- binary_sensor.front_door
- binary_sensor.back_door
- binary_sensor.side_door
- service: input_number.set_value
data_template:
entity_id: "input_number.{{ states('trigger.entity_id').split('.')[1] }}_activations"
value: >
{% set entity = 'input_number.' + [trigger.entity_id].split(".")[1] + '_activations' %}
{{ states(entity) | int + 1 }}
By the way the list of entities is lot longer so I don’t really want to code a separate clause for each one.
Have you considered using a Counter instead of an input_number? Might make things easier since there’s a counter.increment service.
If you want to test templates that use the trigger variable in the template editor, you can enter this first:
{% set trigger = {'entity_id': 'blah.blah', 'to_state': {'state': '123'}} %}
etc. I do this all the time.
But the main problem with your automation is the way you’re using the trigger variable. At a minimum, you need to change it to:
- platform: state
entity_id:
data_template:
entity_id: "input_number.{{ trigger.entity_id.split('.')[1] }}_activations"
value: >
{% set entity = 'input_number.' + trigger.entity_id.split(".")[1] + '_activations' %}
klogg
(Klogg)
September 12, 2018, 6:06am
3
I hadn’t but I will. Thank you.
And thank you too for the test template which I will store away for future use, and the code corrections even if now I don’t end up using them.
klogg
(Klogg)
September 12, 2018, 9:00am
4
Counters worked brilliantly. Until I realised they get reset after every HA restart!
