Incremental backups with rsync
I had some code lying around from another project and I minified it. I use this to automatically do incremental backups of my home assistant folder (or only the config one). I put it with 5 minute delay and run it with cron.
What this does:
  • first time, it makes a full copy of your folder in /backups/year_month_day_hour_minute_second
  • second time and afterwards, it makes hard links to the previous backup, then copies the changes over
Non-technical: It makes a backup of your files, copying the least amount of data possible. Each backup looks like it has all the files, but it only contains the difference. If you have a 100MB folder, and made 3 backups with 5 MB for each 2 changes, you would need:
  • 100 mb for first backup
  • ~5MB for second backup
  • ~5MB for third backup
github: https://github.com/vladbabii/php_rsync_incremental_backups
original ideal: http://www.mikerubel.org/computers/rsync_snapshots/
How to use:
  • install php-cli
  • copy the .php file somewhere on your server
  • edit the first part of the file
    $C[‘timezone’ ] = ‘America/New_York’;
    $C[‘from’ ] = ‘/path/to/config/files’;
    $C[‘to’ ] = ‘/path/to/backups’;
    $C[‘keep’ ] = 1000;
    $C[‘rounding’ ] = 605;
    $C[‘rsync’ ] = ‘rsync’;
    $C[‘behind’ ] = 20160
    4;
  • set it up with cron every X minutes
Values:
  • to / from
  • timezone: see http://php.net/manual/en/timezones.php
  • keep - how many backups to keep
  • rounding - make a backup at most X seconds (in the above example: 5 minutes)
  • rsync executable path
  • behind - how many backups to look back for a good one for the diff
If you only want to use rsync, look at the original article, you only need to run this in the /backups/ folder:
rm -rf backup.3
mv backup.2 backup.3
mv backup.1 backup.2
mv backup.0 backup.1
rsync -a --delete --link-dest=../backup.1 source_directory/  backup.0/
where
  • source_directory = path to your config / home assistant folder
This will create a maximum of 4 backups (0 1 2 3) and every time you run the script it will delete the older one, move others one down, then create a new backup.
If you want to use it and don’t know how
  • create a folder for backups
  • edit a file with ssh ( nano run-backups.sh )
  • put in the above commands and edit source_directory
  • save the files ( in nano control+x then y )
  • run it with bash run-backups.sh
In cron add command
cd /folder/with/backups/ && bash run-backups.sh
I’d also look at rsnapshot. It’s also a wrapper for rsync, and is designed for calling from cron.
