Incremental Brightness increase doesnt work with ikea tradfri e14
So i wrote this script which should increase the brightness until it is 255. When i run the script nothing happens. Not even an error message. Does anybody has a solution?
alias: increasing_brightness_lightbuld_1
sequence:
  - repeat:
      while:
        - condition: numeric_state
          entity_id: light.led_lampe_1
          attribute: brightness
          below: 255
      sequence:
        - service: light.turn_on
          data_template:
            transition: '60'
            brightness: >
              {% set n = states.light.led_lampe_1.attributes.brightness + 25 %}
              {% if n > 255 %}
                255
              {% else %}
                {{ n }}
              {% endif %}
mode: single
icon: 'hass:lightbulb'
Why don’t you just set a high transition value to turn the light on? Should do the same, although I don’t know if that’s supported.
When you run the script, does it turn on the light at all?
So thx for the response. Your solution with the high transition value worked for me. And no the script does not turn on the lights. for that i use another script in which i now added the transition.
