I found this blueprint for the moes knob to control dimable lights, and im trying to adapt it so instead of control the brightness of all input lights it uses the single press event to select one of the input lights and only aply the automation too that one. When one clicks the button it goes to the next one a so on. So basically the button selects the light from the inputs and the rotation knob applies the change in brightness. What i have so fare looks like this:
blueprint:
name: Knob for livingroom lights
description: "Switch between lights and control light brightness"
domain: automation
input:
remote:
description: Moes Knob to use
selector:
device:
integration: zha
manufacturer: _TZ3000_qja6nq5z
model: TS004F
multiple: false
lights:
description: The light(s) to control
selector:
entity:
domain: light
mode: restart
max_exceeded: silent
- platform: event
event_type: zha_event
event_data:
device_id: !input remote
- variables:
command: "{{ trigger.event.data.command }}"
cluster_id: "{{ trigger.event.data.cluster_id }}"
args:
"{% if trigger.event.data.args[0] == 0 %} 0 {% elif trigger.event.data.args[0]
== 1 %} 1 {% elif trigger.event.data.args[0] == 3 %} 3 {% endif %}"
selected_light: 0 # Selected index by the single press event
- choose:
- conditions: # this is the single press event
- "{{ command == 'toggle' }}"
- "{{ cluster_id == 6 }}"
sequence:
# Here goes the code to switch the index on button press ??
# My idea is to change the selected_light variable to use as index
# on the next automations
- conditions:
- "{{ command == 'step' }}"
- "{{ cluster_id == 8 }}"
- "{{ args == 0 }}"
sequence:
- repeat:
while:
- condition: template
value_template: "{{ repeat.index < 2 }}"
sequence:
- service_template: lights.turn_on
target: !input lights # Instead of this, get the target from the variable selected_light
data_template:
brightness_step_pct: 5
transition: 0.5
I added some comments on what i’ve been trying, my thought process. But im not being able to get my head around this. And to be honest i dont even know if this is possible.
Any ideas on this? tks in advance
EDIT:
It would be awesome to be able to provide a blueprint of this to the community, but unfortunately i wasn’t able to do this. And i dont really think, now that i learned a bit more about how this things work, this would be possible with a single blueprint.
So, what i did to make this automation to work was:
First of all, make sure the knob is in the scene mode (triple press the knob changes the mode).
I created an input number helper, in my case input_number.knob_selected_device
that is used to identifies which light the knob should affect (Ex: 1 → living room lights, 2 → dining room lights, etc).
Then I created an automation for when pressing the knob changes the input to the right number. Because of the way automations work i need one of this automatons for each light i want to use. EX:
alias: knob-chose-living-room
description: ""
- platform: event
event_data:
device_id: <<KNOB-DEVICE-ID>>
condition: []
- variables:
- choose:
- conditions:
value_template: "{{ command == 'toggle' }}"
value_template: "{{ cluster_id == 6 }}"
- condition: state
entity_id: <<INPUT-NUMBER-HELPER>>
state: "<<PREV_STATE_VAL>>" # HERE GOES THE PREVIOUS VALUE, EX: "1.0"
sequence:
- service: input_number.set_value
metadata: {}
value: "<<NEXT_VAL>>" # HERE GOES THE PREV_STATE_VAL + 1, OR 1 IF THE PREV VALUE IS THE LAST ONE, Ex: "2"
- if:
- condition: state
entity_id: <<LIGHT-TO-AFFECT-ID>>
state: "off"
then:
- service: light.turn_on
brightness_pct: 25
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
- service: light.turn_off
metadata: {}
data: {}
- if:
- condition: state
state: "on"
then:
data: {}
- delay:
hours: 0
minutes: 0
seconds: 0
milliseconds: 500
metadata: {}
data: {}
mode: single
This, not only puts the helper with the right index, but blinks the selected light so i can have a visual input of what light is selected.
Then I have the automation that affects the brightness. Again, one for each light i want to control:
alias: knob-living-lights
description: ""
- platform: event
event_data:
- variables:
args: >-
trigger.event.data.args[0] == 1 %} 1 {% elif trigger.event.data.args[0]
- choose:
- conditions:
value_template: "{{ command == 'step' }}"
value_template: "{{ cluster_id == 8 }}"
value_template: "{{ args == 0 }}"
- condition: state
state: "<<THIS-LIGHT-INDEX>>" # EX. "2.0"
sequence:
- repeat:
while:
sequence:
metadata: {}
brightness_step_pct: 10
- conditions:
value_template: "{{ args == 1 }}"
- condition: state
sequence:
- repeat:
while:
sequence:
metadata: {}
brightness_step_pct: -10
mode: single
And yeah, with this all seems to work just fine. Just a bit cumbersome than i would likebut it is what it is.
