Infineon PROFET Smart High-Side Switch
Hi. My name is Sasha, and this is my first post here. I am in the planing fase for the truck to camper conversion. I would like to monitor and automate all sorts of things in the camper. Sensors are there, relays are out of the quesion, and I havent found MOSFET board that I like. What caught my attention is Infineons PROFET Smart High-Side Switch series. It is actually very robust logic-level MOSFET IC with all sorts of protections and diagnostics. One of it`s features I found very interesting is a current sense feedback. There are varous evaluation boards available, but most of them are arduino form factor. I got myself a Microelectronica PROFET CLICK - 15A to play with: PROFET Click - 15A After some playing with it, I liked it, so I have designed a custom DIN rail ready PCB containing 4 PROFETs. It looks like this…
i2c:
  sda: GPIO21
  scl: GPIO22
  scan: True
ads1115:
 - address: 0x48
   continuous_mode : on
# ads1115-48
  - name: "OUTPUT 01"
    ads1115_id: ads1115_48
    multiplexer: 'A0_GND'
    gain: 6.144
    platform: ads1115
    update_interval: 1s
    unit_of_measurement: "A"
    icon: "mdi:gauge"
    accuracy_decimals: 2
    filters:
      - calibrate_linear:
         - 0.000 -> 0.000
         - 0.386 -> 6.20
  - name: "OUTPUT 02"
    multiplexer: 'A1_GND'
    gain: 6.144
    platform: ads1115
    update_interval: 10s
    icon: "mdi:gauge"
    filters:
      - calibrate_linear:
         - 0.132 -> 0.000
         - 3.295 -> 3.3
  - name: "OUTPUT 03"
    multiplexer: 'A2_GND'
    gain: 6.144
    platform: ads1115
    icon: "mdi:gauge"
    filters:
      - calibrate_linear:
         - 0.129 -> 0.000
         - 3.295 -> 3.3
  - name: "OUTPUT 04"
    multiplexer: 'A3_GND'
    gain: 6.144
    platform: ads1115
    icon: "mdi:gauge"
    filters:
      - calibrate_linear:
         - 0.132 -> 0.000
         - 3.295 -> 3.3
switch:
  - platform: gpio
    pin: GPIO26
    inverted: False
  - platform: gpio
    pin: GPIO25
    inverted: False
  - platform: gpio
    pin: GPIO33
    inverted: False
  - platform: gpio
    pin: GPIO32
    inverted: False
binary_sensor:
  - platform: gpio
    pin:
      number: GPIO16
      mode: INPUT_PULLUP
      inverted: true
    filters:
      - delayed_on: 3ms
      - delayed_off: 3ms
    on_click:
      then:
        - switch.toggle: profet1
  - platform: gpio
    pin:
      number: GPIO17
      mode: INPUT_PULLUP
      inverted: true
    filters:
      - delayed_on: 3ms
      - delayed_off: 3ms
    on_click:
      then:
        - switch.toggle: profet2
  - platform: gpio
    pin:
      number: GPIO18
      mode: INPUT_PULLUP
      inverted: true
    filters:
      - delayed_on: 3ms
      - delayed_off: 3ms
    on_click:
      then:
        - switch.toggle: profet3
  - platform: gpio
    pin:
      number: GPIO19
      mode: INPUT_PULLUP
      inverted: true
    filters:
      - delayed_on: 3ms
      - delayed_off: 3ms
    on_click:
      then:
        - switch.toggle: profet4
I am not a coder and I am not using full diagnostics even the Infineon has provided a library. I am using ESPhome, and For now, I can just switch it on/off and measure the current with ADS1115. It would be amazing to have full diagnostics and some ESPHome template that can be adjusted to act as an electronic fuse. I will provide more details about the PCB when I get back home. Please comment and advise.
Smart High-Side Switch Arduino Library:
Stumbled upon those IC’s yesterday, also planning making decentral boards for my coming campervanbuild and thinking of such kind of boards. Still in doubt if I’m gonna use ESPHome or Canbus…
