Influx Connection fails with: '401: "error":"authorization failed"
Hello, I would like to use an existing (external) Influx instance as a sensor in HA.
I have the following setup:
Server 1: Homeassistant OS installed
  • Core 2024.1.3
  • Supervisor 2023.12.0
  • Operating System 11.4
  • Frontend 20240104.0
  • The “InfluxDB” plugin is installed, which also allows me to connect to the Influx instance of Sever2 and create queries.
Server 2: Influx instance
  • version 1.8.10
  • IP: 192.168.28.77
  • database “monitoring”
  • user name and password are assigned.
  • SSL is not used
I would like to use data from Server2 as a sensor.
Here is my config.yaml
influxdb:
  exclude:
    entity_globs: “*”
And here sensors.yaml
- platform: influxdb
  host: 192.168.28.77
  port: 8086
  database: monitoring
  username: config
  password: "myPassword"
  ssl: false
  api_version: 1
  queries:
    - name: zimmertemperatur_bad
      unit_of_measurement: °C
      value_template: "{{ temperature_C | round(1) }}"
      #where: 'time > now() - 7d'
      where: 'time = now()'
      measurement: '"monitoring"."autogen"."LaCrosse-TX141THBv2"'
      field: "temperature_C"
      group_function: last
But I get the following error:
[homeassistant.components.influxdb] InfluxDB database is not accessible due to '401: {"error":"authorization failed"}'. Please check that the database, username and password are correct and that the specified user has the correct permissions set. Retrying in 60 seconds.
Why can’t Homeassistant query any values via the YAML configuration?
It can’t be a user restriction because the Influx plugin from Homeassistant connects to Server2 without any problems.
