so ive never been able to get influx db to work in home assistant, i know alot of people use it so figured i might be able to get it set up here
heres my yaml for it
influxdb:
host: 192.168.1.210
port: 8086
database: homeassistant
username: homeassistant
password: hidden
ssl: false
verify_ssl: true
max_retries: 3
default_measurement: state
iheres the error logs i keep getting
Logger: homeassistant.components.influxdb
Source: components/influxdb/init.py:479
Integration: InfluxDB (documentation, issues)
First occurred: 10:57:56 AM (4 occurrences)
Last logged: 11:00:56 AM
Cannot connect to InfluxDB due to ‘HTTPConnectionPool(host=‘192.168.1.210’, port=2086): Max retries exceeded with url: /write?db=homeassistant (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f92690580>: Failed to establish a new connection: [Errno 111] Connection refused’))’. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible. Retrying in 60 seconds.
Cannot connect to InfluxDB due to ‘HTTPConnectionPool(host=‘192.168.1.210’, port=2086): Max retries exceeded with url: /write?db=homeassistant (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f8085c0a0>: Failed to establish a new connection: [Errno 111] Connection refused’))’. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible. Retrying in 60 seconds.
Cannot connect to InfluxDB due to ‘HTTPConnectionPool(host=‘192.168.1.210’, port=2086): Max retries exceeded with url: /write?db=homeassistant (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f85d2c460>: Failed to establish a new connection: [Errno 111] Connection refused’))’. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible. Retrying in 60 seconds.
Cannot connect to InfluxDB due to ‘HTTPConnectionPool(host=‘192.168.1.210’, port=2086): Max retries exceeded with url: /write?db=homeassistant (Caused by NewConnectionError(’<urllib3.connection.HTTPConnection object at 0x7f811d3640>: Failed to establish a new connection: [Errno 111] Connection refused’))’. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible. Retrying in 60 seconds.
