I am trying to read some energy data into a sensor in Home Assistant from InfluxDB (2.x.x) to display it in the energy dashboard. Somehow, I am not getting the syntax right, and find it difficult to know what the errors are. Hope someone here can guide me a bit, what I have so far:
- platform: influxdb
api_version: 2
organization: XXX
token: !secret token
host: !secret local_ip
port: 8086
ssl: false
bucket: ctc/autogen
queries_flux:
- name: heater_effect
range_start: "-1d"
unique_id: influx001
unit_of_measurement: W
query: >
filter(fn: (r) => r["_measurement"] == "electric power")
|> filter(fn: (r) => r["_field"] == "Heater")
|> keep(columns: ["_value", "_time"])
The data is read into the influxdb database in batches from a USB stick (logging my CTC EcoZenith heater) manually at varying frequency.
If I query it without the range_start
variable it will populate the HA sensor with the latest value from the database (but no historical data will show).
If I query it with range_start: "-1d"
it will populate the home assistant sensor with yesterdays data as a starting point and add data that are 24 hours offset continuously until there are no more data in InfluxDB.
Is it possible to populate a HA sensor with historical data at all?
