Good afternoon,
I’ve poured over the forums trying to piece together a solution but i think i have hit a wall.
I have InfluxDB setup and sending data to the cloud but I would like to filter the data down a bit. I’ve read multiple articles but i can’t seem to get it to work like i want. YAML Below.
I would like to only capture data for my ecobee thermostats, ecobee remote sensors and Aero Humidty/Termperature sensors.
Sample device names:
sensor.master_bedroom_sensor_temperature
sensor.upstairs_humidity
sensor.downstairs_humidity
sensor.aerq_temperature_and_humidity_sensor_v1_0_air_temperature
sensor.aerq_temperature_and_humidity_sensor_v1_0_humidity
What is the best way to only record these sensors/entities? I dont wan to include each manually in the YAML. I’ve also looked at GLOB filtering (see yaml below) but it doesn’t seem to work.
Any help is greatly appreciated!
influxdb:
api_version: 2
ssl: true
host: blahblahb
token: blahblahb
organization: blahblahb
bucket: home_assistant
tags:
source: HA
tags_attributes:
- friendly_name
default_measurement: units
include:
domains:
- sensor
entity_globs:
- sensor.*_humidity
- sensor.*_temperature
- sensor.*_*_*_*_*_*_*_*_temperature
