I dont know if this is possible
buth how can you convert the complete internal db to influxdb so that it can work with grafana
Do i have to convert the existing database or does there exist a tool to add this internal db to grafana?
i would like to control all sensors in influxdb, if possible
otherwise if not only certain sensors like powermanagement for making monthly graphs
Thanks for the swift respons
I quickly read the influx link you provided.
if im correct i can send certain entitys to this influx.
i know how to connect influx with grafana so this would not be a problem .
My main concern is in this setup data duplication
Currently my internal db is 4gb big and hassio is only running for 2 weeks (really this concerns me what does it al store???)
So if i setup an influx would there be data duplication or not?
or even better would it be stored ONLY on the influx db and not on the internal db
is there a way to view the internal db?
make it smaller perhaps?
Hi i just was looking op the recorder functionµ
Installed the sql lite addon and saw a lot of useles (like sun.sun) entities that recorded like hell
i will look into this further by the recorder option for maken the db smaller
the grafana/influxpart if i shrinked the db enough i will allow de duplication in influx
