I’ve started to integrate esphome into my HA installation, with a simple configuration:
- platform: wifi_signal
update_interval: 60s
which reports the wifi signal strength to HA as expected and shows up as the entity sensor.wifi_signal
. The device itself is properly recognized in HA with it’s name test1
. However, the metrics send to InfluxDB do not contain any device id. So with a second/third device with the same configuration, I’m unable to distinguish the devices. The only tags available on the InfluxDB records are domain
, which is set to sensor
and entity_id
which is set to wifi_signal
I’ve tried tags_attributes
in the HA InfluxDB configuration, but this directive only copies attributes from the State object as tags and the tags
options is a static mapping of tags.
Sure, i could rename each entity to something like sensor.test1_wifi_signal
but this becomes tedious really fast. Is it possible to send the device id (test1
in this case) as a tag to InfluxDB?
