Influxdb does not register "number"?
I noticed recently that I can’t see my selected room temperature onymore on grafana (with InfluxDB)
After some digging, on InfluxDB I can only see the values of “sensors”, but not “numbers”
So in example
InfluxDB contains values for
sensor.thermostat_hc1_current_room_temperature
sensor.thermostat_floor_drying_temperature
But InfluxDB does NOT contain values for
number.thermostat_hc1_selected_room_temperature
For some reason/update/upgrade, my
sensor.thermostat_hc1_selected_room_temperature
is converted to
So my questions
  • how can I instruct InfluxDB to register numbers ?
  • why do some entities have their values reported as “sensor” and sometimes as “number”? (In the past I could use “sensor.thermostat_hc1_current_room_temperature”)
kind regards,
Bart
PS: my InfluxDB config:
# INFLUXDB + GRAFANA
influxdb:
  username: homeassistant
  password: xxxxxxxx
  max_retries: 3
  default_measurement: state
  include:
    domains:
      - light
    entity_globs:
      - sensor.*_temperature
      - sensor.*_humidity
      - sensor.*_pressure
      - sensor.*_power
      - number.*_temperature
      - number.*_humidity
      - number.*_pressure
      - number.*_power
      - binary_sensor.*_occupancy
    entities:
      - sensor.thermostat_error_code
      - sensor.boiler_burner_current_power
      - sensor.boiler_heating_pump_modulation
      - sensor.boiler_heat_pump_modulation
      - sensor.boiler_service_code_number
      - sensor.boiler_system_pressure
      - sensor.boiler_warm_water_current_tap_water_flow
      - sensor.boiler_warm_water_current_temperature_extern
      - sensor.boiler_warm_water_current_temperature_intern
      - sensor.boiler_warm_water_disinfecting
      - sensor.boiler_warm_water_heating
      - sensor.boiler_warm_water_set_temperature
      - sensor.boiler_warm_water_storage_temperature_extern
      - sensor.boiler_warm_water_storage_temperature_intern
      - sensor.tasmota_111_energy_power
      - sensor.tasmota_113_energy_apparentpower
      - sensor.tasmota_113_energy_current
      - sensor.tasmota_113_energy_factor
      - sensor.tasmota_113_energy_power
      - sensor.tasmota_113_energy_reactivepower
      - sensor.tasmota_113_energy_today
      - sensor.tasmota_113_energy_total
      - sensor.tasmota_113_energy_totalstarttime
      - sensor.tasmota_113_energy_voltage
      - sensor.tasmota_113_energy_yesterday
  component_config:
    counter.hotw:
      override_measurement: lt
  component_config_glob:
    sensor.*humidity:
      override_measurement: humidity
    sensor.*temperature:
      override_measurement: temperature
    sensor.*battery:
      override_measurement: battery
    number.*humidity:
    number.*temperature:
    number.*battery:
