I’m using the influxdb integration to write some sensor values into influxdb
My config is like so:
host: a0d7b954-influxdb
port: 8086
database: hass
username: hass
password: elided
max_retries: 3
default_measurement: state
tags_attributes:
- friendly_name
- FeedName
- device_class
- Tag
I’m getting this error in my home-assistant.log:
2019-12-30 19:23:33 ERROR (InfluxDB) [homeassistant.components.influxdb] Write error: 400: {"error":"partial write: field type conflict: input field \"state\" on measurement \"state\" is type string, already exists as type float dropped=1"}
2019-12-30 19:23:34 ERROR (InfluxDB) [homeassistant.components.influxdb] Resumed, lost 1 events
2019-12-30 19:25:34 ERROR (InfluxDB) [homeassistant.components.influxdb] Write error: 400: {"error":"partial write: field type conflict: input field \"state\" on measurement \"state\" is type string, already exists as type float dropped=1"}
2019-12-30 19:25:35 ERROR (InfluxDB) [homeassistant.components.influxdb] Resumed, lost 14 events
2019-12-30 19:27:35 ERROR (InfluxDB) [homeassistant.components.influxdb] Write error: 400: {"error":"partial write: field type conflict: input field \"state\" on measurement \"state\" is type string, already exists as type float dropped=1"}
2019-12-30 19:27:36 ERROR (InfluxDB) [homeassistant.components.influxdb] Resumed, lost 14 events
How do I go about figuring out the sensor(s) that are causing the problem and in any event how to fix it.
I presume that Influxdb “guessed” the type as float based on an initial value but later values can’t be parsed as floats?
Thanks,
Steve
