I’m trying to configure HA to read data from a remote InfluxDB 2.xx server (on the same LAN) in order to set HA sensor states/values. I do not want to write any HA entity data to InfluxDB.
My problem is that HA cannot establish a connection with the InfluxDB server. The HA log has entries like this:
023-07-09 10:18:53.122 ERROR (SyncWorker_8) [homeassistant.components.influxdb] Cannot connect to InfluxDB due to '<urllib3.connection.HTTPConnection object at 0x7f8b098b10>: Failed to establish a new connection: [Errno 111] Connection refused'. Please check that the provided connection details (host, port, etc.) are correct and that your InfluxDB server is running and accessible. Retrying in 60 seconds.
I have checked the host, port, organisation id, token values carefully. I can connect remotely to the InfluxDB server using the same values from the InfluxCLI tool. If I knew how to install an InfluxCLI tool on the HA RPi, I would try that…
Setup details:
- Home Assistant 2023.7.1 using the HassOS image running on a RPi4 (OS: 10.3).
- InfluxDB OSS version 2.7.1.
My configuration.yaml file includes the following:
influxdb:
api_version: 2
host: 192.168.2.2
ssl: false
organization: a175c98ba00784f7
token: ThL80NgQ...==
exclude:
entity_globs: "*"
- platform: influxdb
api_version: 2
host: 192.168.2.2
ssl: false
queries_flux:
- name: power_consumed_live
unique_id: power_consumed_live_id
bucket: "envoy/autogen"
unit_of_measurement: "W"
range_start: "-2m"
range_stop: "now()"
query: >
last()
|> filter(fn: (r) => r["_measurement"] == "3phasepower")
|> filter(fn: (r) => r["_field"] == "p")
|> filter(fn: (r) => r["type"] == "total-consumption")
|> group(columns: ["_time"])
|> sum()
Does anyone have any suggestions for troubleshooting this?
