dakkerd
(Dirk Dorme)
December 27, 2021, 3:43pm
1
I followed, or try to, video of frenck on adding an influxDB and monitoring state changes of Home assistant.
So I added a db, with a user and permissions all to the influxDB
I modified the config yaml using the instructions as follows:
influxdb:
host: a0d7b954-influxdb
port: 8086
database: homeassistant
username: homeassistant
password: <yourpassword>
max_retries: 3
default_measurement: state
That should do it to show some retentionpolicy on the explore tab of influxdb. But there is no db.retentionpolicy to be found anywhere.
Any pointers?
Mikefila
(Mike Fila)
December 27, 2021, 4:00pm
2
Go to influx -->admin(crown icon), highlight the DB and edit. There you can then change the retention policy.
dakkerd
(Dirk Dorme)
December 27, 2021, 4:01pm
3
The retention policy is infinite. I mean that there is nothing showing up on the explore tab.
Mikefila
(Mike Fila)
December 27, 2021, 4:09pm
4
On that page top left, there is a drop down. Is your instance selected?
dakkerd
(Dirk Dorme)
December 27, 2021, 4:10pm
5
It might not, but equally no idea what exactly you are referring to. Full screenshot:
Dropdown gives me this:
Mikefila
(Mike Fila)
December 27, 2021, 4:12pm
6
Where it says dynamic sources, but It should show with that selection. There should be another option for localhost.
dakkerd
(Dirk Dorme)
December 27, 2021, 4:13pm
7
Indeed, modified previous post. Allow me to add the dropdown again:
Mikefila
(Mike Fila)
December 27, 2021, 4:19pm
8
That’s it, it’s set right. Is there anything in the addon log in the supervisor?
dakkerd
(Dirk Dorme)
December 27, 2021, 4:21pm
9
I get this:
time="2021-12-27T17:19:42+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:50136" response_time=2.546317ms status=200
time="2021-12-27T17:19:44+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:50154" url=/Roboto-Medium.7030d125.ttf
time="2021-12-27T17:19:44+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:50154" response_time=129.095454ms status=200
time="2021-12-27T17:19:45+01:00" level=info msg="Response: No Content" component=server method=GET remote_addr="127.0.0.1:50158" response_time=1.340306ms status=204
time="2021-12-27T17:19:45+01:00" level=info msg="Serving assets" component=server method=GET remote_addr="127.0.0.1:50160" url=/RobotoMono-Medium.ed4bd09b.ttf
time="2021-12-27T17:19:45+01:00" level=info msg="Response: OK" component=server method=POST remote_addr="127.0.0.1:50162" response_time=2.223115ms status=200
time="2021-12-27T17:19:45+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:50160" response_time=76.389242ms status=200
time="2021-12-27T17:19:51+01:00" level=info msg="Response: OK" component=server method=GET remote_addr="127.0.0.1:50198" response_time="97.944µs" status=200
Seems ok to me, but nothing shows up anyway.
dakkerd
(Dirk Dorme)
December 27, 2021, 4:40pm
10
If relevant: running the metaquery SHOW DATABASES
it does not show anything either. So something is wrong with the DB’s (I’m guessing). Tripple checked db, user and pass. Dead end.
Mikefila
(Mike Fila)
December 27, 2021, 4:47pm
11
Is this a new install or is this something that was working and stopped? Do you have grafana installed, is there data there?
Just to be sure it’s not a browser/machine error, have you tried accessing it from the app or another machine/browser?
dakkerd
(Dirk Dorme)
December 27, 2021, 4:58pm
12
This is a new installation, a previous one did not work for me either. I indeed hoped with a new install…
When submitting the metaquery it keeps on ‘spinning’, aka it does not give any results. Would the PI not be powerfull enough to run influxdb?
There is no data in grafana.
dakkerd
(Dirk Dorme)
December 27, 2021, 4:59pm
13
Thanks!
Indeed, a browser issue. Safari works just fine, FF does not.
Waw, I’ve should have tried that before. I do apologize!
