InfluxDB not populating with include domain
In an effort to minimize junk data logging I began setting include entities/domains for the components recorder, logbook, history and influxdb
Using only includes (no excludes) I set the same values for all four components and restarted Home Assistant. Immediately I noticed my Graphana graphs were stuck at the latest values before restart. After much troubleshooting I’ve come to conclusion:
If I use the include domain: in the influxdb component, nothing is logged to influxdb.
Here’s an example of a config not working:
> influxdb:
>   host: 127.0.0.1
>   port: 8086
>   username: !secret influxdb_user
>   password: !secret influxdb_pass
>   database: !secret influxdb_database
>   include:
>     entities:
>       - sensor.multisensor_ute_temperature
>       - sensor.rain_general
>       - sensor.ups_power_status
>       - sensor.yr_temperature
> 	domains:
>       - automation
>       - device_tracker
>       - light
>       - switch
If I omit the domains: section it starts logging to influxdb again.
I’ve now tried removing individual entries from the domains: list but it didn’t change anything, as long as the domains: is present it does not log anything.
Running Home Assistant official Docker image 55.2
Any ideas?
Edit: I can see the intendation is wrong in this paste, but it is not in the configuration file.
This certainly could be true. I only specify entities in my configuration.
I am experiencing this as well. Any workarounds or fixes?
domains: is not correctly indented in the code you sent. Add 2 spaces and it should work. Mine does…
