I want to store all my sensor data in Influx but doesn’t appear to be populating with any data. HA can see Influx, as it created fields for the sensor names - but doesn’t appear to populate any measurements.
I’m running the latest version of HA 0.38.3. Is the InfluxDB integration functioning ?
It is working fine for me with 0.38.3 with influxdb and grafana.
I seem to remember, from when I was getting started, that adjusting the grafana display was a bit of a problem. Clicking the time at the top right hand corner and choosing ‘last 3 hours’ eventually got some data displayed.
Installed InfluxDB and Grafana yesterday for testing purposes and configured HA to use it. It took some time, but it was populated by HA. Unfortunally, the “climate” domain was not pushed, so I removed everything again.
Thanks for your help. Is there a command I can run in the Influx CLI that should show me data. The example under the Influx HA blog page says to try “SELECT * FROM binary_sensor”. This doesn’t return anything and tried this for all combinations of sensors I haave and still nothing.
pi@raspberrypi:/home/homeassistant/.homeassistant
$ influx
Visit https://enterprise.influxdata.com to register for updates, InfluxDB server management, and monitoring.
Connected to http://localhost:8086 version 1.1.0
InfluxDB shell version: 1.1.0
> use home_assistant
Using database home_assistant
> select "value" from "binary_sensor.lounge_motion_sensor"
time value
1480689103831160064 0
1480689545270433024 0
