First of all: I am running:
Home Assistant 2022.11.4
Supervisor 2022.11.2
Operating System 9.3
Frontend 20221108.0 - latest
For long term availability (instead of the internal DB which is SQLite if I am not mistaken), I installed influxDB with the community addon.
However, I am missing some basic and I am sorry for this lack of experience.
I have created the db
homeassistant
according to the docs of the addon mentioned above, bit I can’t find it on my system (just want to check if its size is increasing). Some says it’s in/usr/share/hassio/share/
but there is nothing to be found (no hassio directory). -
I tried to
QUERY
using the UI by:
SELECT "temperature" FROM "sensor.carbon_monoxide_sensor_air_temperature" WHERE time > now() - 24h;
but I get database name required
How to fix this?
Any simple check to verify if there is data written to the homeassistant
DB at all?
The DB is obviously there:
What about the permissions? The docs don’t mention that something needs to be changed after creating the DB. -
The Hosts List does not show any hosts (I assume that’s because it’s the localhost only?
The Connections Tab shows this:
EDIT:
About 1:
I tried
docker exec -it addon_a0d7b954_influxdb /bin/bash
But there is no homeassistant DB either:
root@a0d7b954-influxdb:/data# ls -la
total 48
drwxr-xr-x 4 root root 4096 Nov 26 08:21 .
drwxr-xr-x 1 root root 4096 Nov 26 08:20 ..
-rw------- 1 root root 32768 Nov 27 09:21 chronograf.db
drwxr-xr-x 5 root root 4096 Nov 26 08:21 influxdb
drwxr-xr-x 3 root root 4096 Nov 26 08:20 kapacitor
-rw------- 1 root root 130 Nov 26 08:20 options.json
-rw-r--r-- 1 root root 33 Nov 26 08:20 secret
