InfluxDB restarting
Hello
My InfluxDB restarts every few minutes and generally doesn’t work. Previously it was working fine, I didn;t change any configuration. I tried to set SSL to false - no difference.
Any ideas?
config:
auth: true
certfile: fullchain.pem
envvars: []
keyfile: privkey.pem
reporting: true
ssl: true
log_level: trace
logs
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/00-banner.sh
 Add-on: InfluxDB
 Scalable datastore for metrics, events, and real-time analytics
 Add-on version: 4.5.0
 You are running the latest version of this add-on.
 System: Home Assistant OS 9.0  (armv7 / raspberrypi3)
 Home Assistant Core: 2022.11.1
 Home Assistant Supervisor: 2022.10.2
 Please, share the above information when looking for help
 or support in, e.g., GitHub, forums or the Discord chat.
cont-init: info: /etc/cont-init.d/00-banner.sh exited 0
cont-init: info: running /etc/cont-init.d/01-log-level.sh
Log level is set to DEBUG
cont-init: info: /etc/cont-init.d/01-log-level.sh exited 0
cont-init: info: running /etc/cont-init.d/02-set-timezone.sh
[08:52:03] INFO: Configuring timezone
cont-init: info: /etc/cont-init.d/02-set-timezone.sh exited 0
cont-init: info: running /etc/cont-init.d/create-users.sh
cont-init: info: /etc/cont-init.d/create-users.sh exited 0
cont-init: info: running /etc/cont-init.d/influxdb.sh
cont-init: info: /etc/cont-init.d/influxdb.sh exited 0
cont-init: info: running /etc/cont-init.d/kapacitor.sh
cont-init: info: /etc/cont-init.d/kapacitor.sh exited 0
cont-init: info: running /etc/cont-init.d/nginx.sh
[08:52:06] DEBUG: Requested API resource: http://supervisor/dns/info
[08:52:06] DEBUG: Request method: GET
[08:52:06] DEBUG: Request data: {}
[08:52:06] DEBUG: API HTTP Response code: 200
[08:52:06] DEBUG: API Response: {"result": "ok", "data": {"version": "2022.04.1", "version_latest": "2022.04.1", "update_available": false, "host": "172.30.32.3", "servers": [], "locals": ["dns://xxx<cut>"], "mdns": true, "llmnr": true, "fallback": true}}
cont-init: info: /etc/cont-init.d/nginx.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun chronograf (no readiness notification)
services-up: info: copying legacy longrun influxdb (no readiness notification)
services-up: info: copying legacy longrun kapacitor (no readiness notification)
services-up: info: copying legacy longrun nginx (no readiness notification)
[08:52:07] INFO: Kapacitor is waiting until InfluxDB is available...
s6-rc: info: service legacy-services successfully started
[08:52:07] INFO: Chronograf is waiting until InfluxDB is available...
[08:52:07] INFO: Starting the InfluxDB...
[08:53:15] INFO: InfluxDB stopped, restarting...
[08:53:16] INFO: Starting the InfluxDB...
[08:54:25] INFO: InfluxDB stopped, restarting...
[08:54:25] INFO: Starting the InfluxDB...
[08:55:35] INFO: InfluxDB stopped, restarting...
[08:55:36] INFO: Starting the InfluxDB...
[08:56:47] INFO: InfluxDB stopped, restarting...
[08:56:47] INFO: Starting the InfluxDB...
[08:57:53] INFO: InfluxDB stopped, restarting...
[08:57:54] INFO: Starting the InfluxDB...
Did you ever solve this? I have the same issue.
