I’ve been using InfluxDB (and Grafana) add-ons for Hassio for about 2 weeks…worked like a charm. At exactly 8pm last night the sensor data stopped creating db entries in InfluxDB. I checked my zwave logs and the sensor is still issuing normal output on a regular basis. Also checked the connection between HA and InfluxDB and it all works perfectly (i.e. I can query the db for older data and the db connection is fine).
I’m having this issue, influxdb was working fine for a couple of weeks, then it stopped creating entities. I uninstalled it and reinstalled it, it worked for a couple of days and now no data is showing up in influxdb. I do have an error in HA which is strange because the error only showed up after it was working.
