InfluxDB stopped recording
I have set up few devices IoT using wemos d1 mini and programmed by myself. I have installed Grafana to track temperature in my home that is connected to influx DB and displays some neet charts. I have noticed that InfluxDB stopped to track history of hassio (it occured twice already). How should I start to debugg and find the reason? Worth mentioning: When I found out that temp stopped being tracked, I had my connection to Internet lost. update: I had last night lost power connection
I cant find logs connected via ssh using terminal, /var/log/ /addons/ are empty
Using web UI in influxDB, I cant get to anykind of logs (looped searching)
In addon view, the one with simple setup, only most recent logs are shown
