Sinds a couple of days, i’ve found this:
InfluxDB database is not accessible due to '401: {“error”:“authorization failed”} '. Please check that the database, username and password are correct and that the specified user has the correct permissions set.
I checked the credentials with a influxdbviewer, and it all works. Even when i check entries of, let’s say, 5 minutes ago, i’ll see new ones in the database. So, it seems it still works. But why is HA giving this error message? I don’t get it.
I’m using the default InfluxDB plugin on HA.
anyone? This still occurs:
Logger: homeassistant.components.influxdb.sensor
Source: components/influxdb/sensor.py:149
Integration: InfluxDB (documentation, issues)
First occurred: 5 maart 2021 11:38:35 (928 occurrences)
Last logged: 9:52:27
Nevermind, found it!
It seems that you’ll also need to enter credentials in sensors of influxdb. Which i hadn’t.
So i added:
username: !secret influxdb_user
password: !secret influxdb_pass
Have a nice day!
Unfortunately not.
Cannot quick reload all YAML configurations because the configuration is not valid: Error loading /config/configuration.yaml: Secret influxdb_user not defined
The real user/password of the used database in InfluxDB don`t work either.
