Hi thanks for your answer.
I perform the command you say and this is what it return:
(homeassistant) pi@raspberrypi:/srv/homeassistant $ hass --debug 2021-05-19 13:59:48 WARNING (MainThread) [asyncio] Executing <Task pending name=‘Task-84’ coro=<_async_setup_component() running at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/setup.py:248> wait_for=<Future pending cb=[<TaskWakeupMethWrapper object at 0xb1d4d3e8>()] created at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/components/recorder/init.py:296> cb=[<TaskWakeupMethWrapper object at 0xb37f5208>()] created at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/core.py:384> took 0.570 seconds
2021-05-19 13:59:48 WARNING (MainThread) [asyncio] Executing <Task finished name=‘Task-146’ coro=<async_setup..setup_panel() done, defined at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/components/config/init.py:46> result=None created at /usr/lib/python3.8/asyncio/tasks.py:382> took 0.117 seconds
2021-05-19 13:59:49 WARNING (MainThread) [asyncio] Executing <Task pending name=‘Task-119’ coro=<_async_setup_component() running at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/setup.py:248> wait_for=<Task pending name=‘Task-180’ coro=<Store._async_load() running at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/storage.py:110> cb=[<TaskWakeupMethWrapper object at 0xb05cee38>()] created at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/core.py:384> cb=[<TaskWakeupMethWrapper object at 0xb09dd430>(), <TaskWakeupMethWrapper object at 0xb09dd2b0>()] created at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/core.py:384> took 0.240 seconds
2021-05-19 13:59:49 WARNING (MainThread) [asyncio] Executing <Task pending name=‘Task-125’ coro=<_async_setup_component() running at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/setup.py:248> wait_for=<Task pending name=‘Task-189’ coro=<Store._async_load() running at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/helpers/storage.py:110> cb=[<TaskWakeupMethWrapper object at 0xafdd08b0>()] created at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/core.py:384> cb=[<TaskWakeupMethWrapper object at 0xb09dd6e8>()] created at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/core.py:384> took 0.447 seconds
2021-05-19 13:59:50 WARNING (MainThread) [asyncio] Executing <Task pending name=‘Task-285’ coro=<_async_setup_component() running at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/setup.py:278> cb=[<TaskWakeupMethWrapper object at 0xafd51898>()] created at /srv/homeassistant/lib/python3.8/site-packages/homeassistant/core.py:384> took 0.597 seconds
after pressing enter on keybord it return this error
2021-05-19 14:03:37 ERROR (MainThread) [root] Uncaught exception
File “/usr/lib/python3.8/asyncio/runners.py”, line 44, in run
return loop.run_until_complete(main)
File “/usr/lib/python3.8/asyncio/base_events.py”, line 603, in run_until_complete
self.run_forever()
File “/usr/lib/python3.8/asyncio/base_events.py”, line 570, in run_forever
self._run_once()
File “/usr/lib/python3.8/asyncio/base_events.py”, line 1823, in _run_once
event_list = self._selector.select(timeout)
File “/usr/lib/python3.8/selectors.py”, line 468, in select
fd_event_list = self._selector.poll(timeout, max_ev)
KeyboardInterrupt
File “/srv/homeassistant/bin/hass”, line 10, in
sys.exit(main())
File “/srv/homeassistant/lib/python3.8/site-packages/homeassistant/main.py”, line 314, in main
exit_code = runner.run(runtime_conf)
File “/srv/homeassistant/lib/python3.8/site-packages/homeassistant/runner.py”, line 118, in run
return asyncio.run(setup_and_run_hass(runtime_config))
File “/usr/lib/python3.8/asyncio/runners.py”, line 51, in run
loop.close()
File “/srv/homeassistant/lib/python3.8/site-packages/homeassistant/runner.py”, line 81, in close
executor.logged_shutdown()
File “/srv/homeassistant/lib/python3.8/site-packages/homeassistant/util/executor.py”, line 83, in logged_shutdown
self.join_threads_or_timeout()
File “/srv/homeassistant/lib/python3.8/site-packages/homeassistant/util/executor.py”, line 98, in join_threads_or_timeout
remaining_threads -= join_or_interrupt_threads(
File “/srv/homeassistant/lib/python3.8/site-packages/homeassistant/util/executor.py”, line 43, in join_or_interrupt_threads
thread.join(timeout=timeout_per_thread)
File “/usr/lib/python3.8/threading.py”, line 1015, in join
self._wait_for_tstate_lock(timeout=max(timeout, 0))
File “/usr/lib/python3.8/threading.py”, line 1027, in _wait_for_tstate_lock
elif lock.acquire(block, timeout):
KeyboardInterrupt
what I can do?
Massimiliano
